Old 08-03-2006, 11:05 AM
bigtoe555 bigtoe555 is offline
key cylinder
i replaced the key cylinder on my 1993 le sabre and now it will not start i get all the dash lights and i waited for the security light to go out and the will not start oh i lost the keys so that is why i replaced the key cylinder and i check all the fuses
Old 08-03-2006, 11:41 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: key cylinder
Hay bigtoe555, welcome to AF!
Saying that it will not "start" leaves out a few items. It could mean that the starter doesn't turn the engine over, or the starter is working but there isn't any spark or fuel to make the engine run. Please let us know which problem you're having.
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 08-03-2006, 12:05 PM
Re: key cylinder
i'm sorry i said i get all the lights on the dash but the do not try to ingage,no power to the starter does not try to turn over i think it's something to with the code even with the security light goes out
Old 08-03-2006, 08:10 PM
kok328 kok328 is offline
Re: key cylinder
Are you using the key that came with the lock cylinder?
Is it of the same resistance as the old cylinder?
Sounds like you have a VATS (Vehicle Anti Theft System) problem.
If you search this board, you'll find how to bypass this system with some resistors and not have to spend $25 for a spare key.
Old 08-03-2006, 08:45 PM
grcore grcore is offline
Re: key cylinder
If you replaced the key along with the cylinder, it does not have the same resistor chip in it. You will need to find out what the resistance should be, which is not easy when you dont have an original key. You will need to figure out which resistor by trial and error.
http://www.asttraining.com/Files/vats1.pdf
Old 08-03-2006, 08:50 PM
Re: key cylinder
that's my problem yes it is the key that come with the cylinder but i had to get a key cut for the code of the computer which it say is code 7 but i don't think it is the right code i had dealer look it up for me and i yes did search the forum for help but did not see how to bypass it i will look again thank you
Old 08-05-2006, 07:07 AM
Thumbs up Re: key cylinder
ok i got the car to start with a 4.7 ohms resistor so what code should i use to get a key made with and thank for help
Old 08-05-2006, 07:50 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: key cylinder
"4750" would be one of the 15 standard GM resistor key blanks.
Old 08-08-2006, 06:50 AM
i had a key made today and everything is works ok i would like to say again thank you guys for all the help
bigtoe555
