| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
hi
i own a 1998 mitsubishi eclipse gs, and i was wondering if any one cou tell me if i would be able to fit an evo 4g63 turbo enguin in my engune bay? |
Re: can i fit an evo engine in my eclipse
Search n00b! If you have to ask, the answer is no. Someone with enough know how and money to do so wouldnt need to ask anyone.
No.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
There is a thread about this on tuners I believe. It might be easier to fit than the eclipse turbo engine but evo motors are expensive.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
I have a simpler solution...
... Buy an Evo.
-Brian
What did Mitsubishi do to fix the crankwalking of the 4g63 in the Evos?
-Brian
Yeah, I dont know. The Evo's are 7 bolts though.
Yeah all the evo's have 7 bolts....I dont think mitsubishi ever even came out and said what caused it.....probably because they dont know...
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
the evo engine is 180 degress the wrong way.
1997 Eclipse GS-T Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head- Interior Modification:-Autometer Boost Gauge http://www.cardomain.com/id/xTeamRedLine23x |
In a nt eclipse the engine sits on the opposite side compared to the turbo so an evo motor would fit easier.
Its not going to happen. Think that 420a tranny is going to bolt up? Nope, neither will a FWD GST tranny. So that means you have to put in the Evo tranny, also a shit ton of money, so then you either get to ghetto the tranny/t case to be FWD or make it AWD (also an load of money). Then what if the drive axles dont line up just right like they most likely wont. This swap is next to impossible for the common DIYer.
This is not even a debate, it's not going to happen, close the thread.
dude you guys are so totally wrong. All you have to do is turn the motor mounts inside out and the motor drops in perfect. I swear you guys need to do some damn research
now - 2000 civic soon - 2002 is300
