Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-03-2006, 01:10 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Clutch Fluid
Hey all;
I finally got a day off tomorrow so I'm going to do that mod where you remmove a little restrictor plate in the clutch line... I think its a 420a mod only, but I'm gong to give it a whirl. Also got some new Alphines for the front, and I'm excited about those too.
Anywho, does it make a big difference if I use DOT3/4 brake fluid or actual clutch fluid for it? I want to stiffen it up, if possible, so is there anyway to do it with the fluid itself? What would you guys choose when draining and refiling your clutch lines? Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-03-2006, 11:45 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Clutch Fluid
I use DOT3 I believe, I dont think it is really going to have that much of a difference. The clutch restrictor is in the 4g63 cars also. I did this mod a few months back and it made a big difference. But I have a performance clutch so I had some chatter when engaging and this mod took all of it out.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-03-2006, 12:26 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Clutch Fluid
Is the restrictor that thing that mounts under the fuse box on our motors? If so, I am removing that too but wasn't sure what it will change about the clutch. Engage smoother or what else does it change?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 08-03-2006, 01:44 PM
Holset powered 420a
Re: Clutch Fluid
the restrictor is where the hard clutch line connects to the slave cylinder. It is a little piece of metal with a spring on it. Its suppose to slow the fluid movement down so that the clutch engages smoothly but I have a high clamp pressure plate and I want the clutch to engage as fast as I can release it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 08-04-2006, 12:18 AM
Re: Clutch Fluid
Awesome, it should work quite nice with mine too then.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 08-04-2006, 02:04 AM
david-b's Avatar
Dave is THAT guy
Re: Clutch Fluid
All I have to say is WOW. I took it out earlier and just drove around. It was ok. No difference in the feeling or anything. Then coming home tonight an older Grand Prix was doing flybys on me, so at a light I burned the hell out of him. OMG, each gear was like butter. I've always had a little problem going from 2nd to 3rd. It was slow, and at higher rpms, I would get almost locked out of going into 3rd. Not anymore. Smooth as better. Clutch gets dropped and engaged smoothly and fast as hell. I love it. Well worth the whole $4 of brake fluid and the $5 for the bleeder kit. I recommend doing this mod for everyone. Just make sure you know how to bleed the clutch and you find pics.
75 Monte Carlo
