Old 08-02-2006, 10:26 PM
danniobrien danniobrien is offline
Unhappy 01 Trailblazer - rough idle - stalls
My 01 blazer has started to idle rough lately when slowing down or coming to a stop. It then ocassionaly stalls while doing this. In addition, sometimes when I start to drive it takes a while for it to shift gears and is very loud. The engine light goes on and off, this happens more when my gas tank drops below a 1/4 tank.
Per the auto shop it's the Throttle Sensor (code 22).
Old 08-02-2006, 10:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 01 Trailblazer - rough idle - stalls
What was the actual code they gave you, OBDII codes aren't two digit numbers.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-03-2006, 04:26 AM
TheBrettster TheBrettster is offline
AF Premium User
yea thats an OBDI code.
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 08-03-2006, 07:02 PM
It's the TPS, PO122. Thought I typed the whole thing in there, sorry.
Old 08-03-2006, 09:47 PM
Okay so I cleaned the throttle body, seeing as that is a common answer given to this type of problem (that stuff stinks!!). Seemed to work great. Then coming home from the store, after stopping a stop sign and then turning, it stalled on me again. arghhh!!!
I am thinking that I need to replace the TPS. Is this a good idea or is there another possible solution?
Old 08-04-2006, 12:50 AM
BlazerLT's Avatar
AF -Advisor
could very well be that seeing the code is pointing to it.
Old 08-07-2006, 03:09 PM
RevJFP RevJFP is offline
I just had a similar problem...rough idle. Same code. Swapped the TPS & it cleared up immediately. Just make sure when you install it that you don't force it straight in. You'll tear up the little plastic "ears" where the TPS mates to the throttle. To get it to seat properly rotate it 5 or 10 degrees clockwise (or to the "right") of how you'll screw it in. Then when it seats firmly, rotate it counter-clockwise until you can get the Torx screws back in.
It's a 10-minute job.
Old 08-07-2006, 07:31 PM
So replaced the TPS (cost 36.98 at advance auto) and the air filter (it was really dirty) now it runs like a champ. I disconnected the negative battery terminal for 30 seconds and it cleared out the computer.
Thanks for all the help..hope this helps someone else!!!
Old 08-07-2006, 08:35 PM
BlazerLT's Avatar
AF -Advisor
Wicked, great to hear.
