Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 08-02-2006, 10:08 PM
fox_dunerider fox_dunerider is offline
2001 Eclipse amp wiring
I am trying to run a power wire up threw the fire wall and I can not find a single place to run it... anyone help please. right now i ran it under the car but i dont like it.
Old 08-02-2006, 10:51 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: 2001 Eclipse amp wiring
Make sure no wires will get drilled into, and drill a hole in the firewall and install a grommet. Don't even think of running that wire thru until you have a grommet..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-03-2006, 06:46 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
I didnt run mine through the firewall....i went through the left front fender, and through the driver door. There is that rubber boot that runs the wires to the factory speakers and power windows from the door to the cabin that I tapped into to run my amp wire. I just used a coat hanger connected to the "O" end of the power wire, dragged it through the fender and ran it through the door....dont even know its there unless you look through the fender.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 08-03-2006, 11:37 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
i would never drill a hole in the fire wall. it is called a fire wall for a reason.
Don't act like you don't love it.
503/2000
Old 08-03-2006, 11:39 PM
Why not? You already have MANY holes in it, from the factory. As long as you install a grommet, your fine. Besides, if engine swarms, you think a thin sheet of steel's gonna keep you protected?
Old 08-04-2006, 02:33 PM
808drifter 808drifter is offline
there should be a hole big enough for the wire near the back of the resonator box on the 4 bangger, (the drivers side)
Old 08-04-2006, 07:48 PM
Sleepr awd's Avatar
yes, but the firewally is structurally sound as well, it doesn't only function as a barrier b/t you and the heat of the engine, it is also a chassis brace and protects you in the event of an accident. i say messing with things that are already structurally sound, is a bad idea.
but hey, it's ur life
503/2000
Old 08-04-2006, 11:07 PM
So those two 1" holes I've drilled into my firewall are going to cause the structural integrity of my car to be de-graded? I guess all those lightening holes drilled in lower control arms and such on factory vehicles is bad?
