Old 08-02-2006, 08:49 PM
justme4732 justme4732 is offline
fan relay for 2000 dodge caravan
Hi everyone,
I'm looking for the location of the fan relay on my caravan. Its a 2000 and it's a 4 cyl. I've seemed to look everywhere and still can't find. Thanks
Justme
Old 08-03-2006, 03:23 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: fan relay for 2000 dodge caravan
Check other threads on the same subject. If you mean the radiator cooling fan look on the frame next to the radiator. If you mean the ventilation blower fan, on 96-98s it's behind the junction block under the dash.
Old 08-10-2006, 06:50 PM
gcq4576 gcq4576 is offline
You wiil find it under the driver side headlight(which you need to rem0ve) bolted to the frame under a black plastic cover! I just changed mine because the radiator fans were not working. The relay is more like a little module and costs around $60. I had to buy mine at NAPA because Checker and Auto Zone don't carry it. The Relay is flat and has two wing looking sides that are bolted to the frame with rivets. I had to remove the rivets on mine with a small hack saw blade. This problem is very common as I have seen on other forums. I bought two small screws and bolts and attached the new relay.
Have a wonderful day
