Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-02-2006, 08:25 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Bad Problems
In every gear except reverse Between 1000 and 2000 rpms If I push the accelerator, the car will accelerate and then cut off and then accelerate again, so it is a jerky motion.
Its like it cuts out then goes back on... IN EVERY GEAR!!!
what could this be????
I have a 1996 mitsu spyder gs eclipse with about 110 K on it now.
hit me back. I will be out of town until monday.
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 08-03-2006, 01:44 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Bad Problems
I dont know what you are talking about. Does it continually jerk or just one?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-06-2006, 08:44 PM
Re: Bad Problems
continually until I hit 2000rpm and above...
[email protected]
Old 08-07-2006, 01:19 AM
92dsmeclipse 92dsmeclipse is offline
Re: Bad Problems
well u might be experiencing fuel cut is the car running stock boost or no any modifications is your blow off valve vented have u done a boost leak test latley and whens the last time u changed your spark plugs and wires go to vfaq.com if u wanna know how to do any of this
Old 08-07-2006, 08:59 AM
SLoe's Avatar
SLoe SLoe is offline
Re: Bad Problems
Probably not a boost leak in a GS Check the throttle position sensor Plugs, wires, and timing.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 08-07-2006, 06:34 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
Re: Bad Problems
I notice my car does about the same thing, but only really after I drive it hard. i have a 98 gst and after I really get on it(race) it drive funky for a while. but i notice its only in the 2k-3k range. It will drive and stutter a little bit to a lot when in that range, whether im at full throttle, half, or no throttle and winding down. if i put it in neutral it stops and idles ok.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 08-08-2006, 12:35 PM
Re: Bad Problems
how do i do all of that...???!
[email protected]
Old 08-08-2006, 12:48 PM
Killa's Avatar
Killa Killa is offline
Re: Bad Problems
If I was you, I go to autozone and buy a haynes repair manual ( for Mitsubishi eclipse & Eagle talon 1995-2001 ) I bought extra one for a $1 ( found at 99 cent table ) .
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-08-2006, 06:36 PM
SLoe's Avatar
Re: Bad Problems
Go get your codes scanned. http://www.2gnt.com/nuke/modules.php...rticle&artid=8
Google is our friend
I agree with the chilton's sugestion.
