Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-02-2006, 07:52 PM
djphild djphild is offline
Overheating when engine off..weird
i have a 97 ply. neon with about 157K kms on it. a year ago replaced the radiator due to a huge crack; hoses are new as well.
recently ive noticed that when i drive the car for a while and turn it off and then turn the ignition back to the electrical accessories (radio and gauges work, engine not running) the temperature gauge shoots up to about 80% of the gauge.
Strangely enuf, the car , while driving and idle, is at a good temperature and doesnt show any overheating. (up to about 40% of the gauge). Is this abnormal and if so whats causing it??
Both electrical fans are working and coolant level is fine. engine oil level is also fine.
djphild
Old 08-02-2006, 08:51 PM
growe58 growe58 is offline
Re: Overheating when engine off..weird
It's called heat soak. The coolant needs to be circulating to shed its heat. When you shut the engine off, the coolant in the block just sits there, absorbing heat. I assume that when you restart the motor, the temperature comes down to normal range. If so, everything is working perfectly normally and there is no need for concern.
Old 08-02-2006, 09:07 PM
ttiiggy ttiiggy is offline
Do you shut the engine off immediately when you stop?
Old 08-03-2006, 12:34 AM
Yes, as soon as i restart the engine the gauge drops to about the 40% range which is about normal for my car.
djphild
Old 08-03-2006, 12:38 AM
Depends. Sometime I do shut it off immediately, like when i get home.
But sometimes when im waiting for someone, I leave the engine running cause Ive heard (correct me if im wrong) that turning off your engine and restarting it within a short period is "bad" for the engine and uses up more fuel.
djphild
Old 08-03-2006, 08:13 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
You get most metal to metal contact on start-up before the oil gets flowing.
Old 08-03-2006, 04:24 PM
I'd like to thank those who replied to my post. The help is greatly appreciated. I dont want to run to a mechanic and have my wallet squeezed dry. Its harder to find a honest mechanic than it is to find a honest woman in my town.....I think.
Has anyone else noticed this "phenomenon" happen to their cars?
djphild.
Old 08-03-2006, 09:20 PM
Wollf's Avatar
Wollf Wollf is offline
Is it only the gauge that is showing a problem ? or are you losing coolant as well , such as your cap is popping open / off and steam hissing or the like.
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Old 08-04-2006, 12:24 AM
Its just the gauge thats showing this increased temperature. My coolant leve is fine. No other problems with the cap or hoses or reservoir. Its all in good shape. I rechecked everything a few hours ago.
djphild
Old 08-06-2006, 02:15 AM
FemaleRacer FemaleRacer is offline
djphild.
My origional Neon's engine did this. (98) And for $200.00 the dealership "fixed it for me so that it wouldn't hurt my engine. Go ahead----everybody laugh. I was young an naieve...lol. Moral of the story...it ran an entire racing season after that doing the exact same thing. And that wasn't what ruined the engine.
Don't let the 34JJ's and 6" heels throw you off...I race to win. No games. Just you in my rearview mirror
