Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-02-2006, 06:06 PM
zm469 zm469 is offline
2000 lincoln town car
i have 2000 lincoln town car , i have electrical problem, when iam driving in hot weather the dash board , ac, radio, almosty every thing exept engine , and the battery light in dash bord blink red , i need help thank you
Old 08-02-2006, 07:38 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 2000 lincoln town car
These kind of problems are usually traced back to bad connections or Alternator/Regulator errors.
First, check the connections at your battery, make sure their clean and tight. The battery itself can be a suspect especially if its more than 2/3 years old -- have it checked for free at an Autozone, Kragens, Pep Boys, etc.
Alternator/Regulator problems have caused all sorts of enomolies in the lighting and electrical systems in these cars. All these systems are electronically controlled via linking Modules that require a steady minimum voltage to function properly.
If the battery checks good, the Alternator (charging system) can also be tested for free at the same places that test battery's.
-Steven
1996 Town Car, Cartier
