Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-02-2006, 05:50 PM
chip78norton chip78norton is offline
99 dodge ram 2500 no overdrive
just got a 20,000 mile dodge 2500 v10 the overdrive does not work .you can push the o/d button & the od on off light goes on but no od..otherwise the tranny works flawless???mabe an o/d sensor , if so where is it?please help..also no cruise , light works cruise does not......
Old 08-02-2006, 05:59 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 dodge ram 2500 no overdrive
Welcome on your first post on AF.
You need to get it on a transmission/engine capable scanner and check codes and read data out.
Post back codes.
MT
MT
Old 08-02-2006, 07:02 PM
also.....just figured this out ive got no kick down..went to autozone but there code reader wasnt working properly
Old 08-03-2006, 02:21 PM
well i think im screwd, no codes came up,& ifigured out i have no first gear,well put it in first, it goes then into 2nd with no rpm drop no shift..then into drive , it will shift while i still have no o/d wtf..........also the tranny does not seem to be slipping
Old 08-03-2006, 03:26 PM
ok i did a little more investigating, #1 reading no codes #2 no o/d #3 1 st gear does work it just dosent like going into it .if i go from park to first it works if not it dosent ..i dont think it engages in drive.(in all of the gears i feel no slippage)#4 kick down doesnot work, k/d cable is attatched. can it be adjusted?this is on a very lifted dodge with a body lift.......please give me some clues!!!!!!!!!!!!!!!!!
Old 08-03-2006, 03:48 PM
MT-2500's Avatar
AF - Advisor
YOU NEED TO FIND A GOOD REPAIR SHOP THAT HAS A TRANSMISSION CAPABLE SCANNER TO CHECK IT OUT.
LOT OF INFO IN ONE OF THEM SCANNERS.
GOOD LUCK MT
MT
Old 08-20-2006, 03:21 AM
moto503 moto503 is offline
Talking Re: 99 dodge ram 2500 no overdrive
i have a 2001 ram 1500 4x4 same problem 2 years ago . solution to fix this is beat the hell out of the tranny till it breaks and get a new one . or spend days under the truck fucking with the thing . it will never be the same if u fix it . just beat it till it busts and drop in a new one
Old 08-20-2006, 01:27 PM
GOOD LUCK MT
took it to a tranny shop...........um they came up with no codes?????????the scanner said that the tranny was shifting through all the gears. dont know now im lost
Old 08-22-2006, 08:06 PM
Re: 99 dodge ram fubar tranny
heres what i have went to aamco it threw a code for a bad 3/4 o/d sensor they replaced it & it did nothing . they rescanned it & came up with the same code took it to dodge they scanned it & came up with the same problem $450 later i got my truck back in the same condition...yeah. i checked the continuity on the harness wire for the o/d {3/4} sensor & the wire is fine from the pcm to the tranny plug .????????? this sucks i need help call me with help 440-319-0531 or [email protected] heres what i have 1 no o/d 2. pud it in drive & it stays in drive no first or second 3. to get into first u must put it in park first then into first....the tranny shop said there are no internal problems with the tranny...this is a 99 2500, 4x4 v10 w/ 46re tranny & 20,000 miles 9.5 in suspension w/ 3 in body lift on 44's...help my truck is the devil
Old 08-22-2006, 08:45 PM
MT-2500's Avatar
AF - Advisor
What was the code no?
MT
MT
Old 08-22-2006, 08:50 PM
MT
ill get it in the morning for you at the moment i forgot it. i was a little pissed i had to pay 450 & got nothing in return...aamco dosent like me any more
Old 08-25-2006, 10:47 AM
sd03ram1500's Avatar
sd03ram1500 sd03ram1500 is offline
never liked em either. i had problems with one of my trannies a while back where it was goin into and out of Lockup. they went thru the tranny, coded it, and found nothing. turns out....get this...the thermostat. had to take the car to future boss's shop and he figured it out without using the puter crap. woohoo! worked like a champ after replaced a $5 thermostat. sooo that would be why i don't go to em. but i agree with some of the others. beat it and break it. seems to be the only way sometimes. wish i could help tho.
on a sidenote (and probably obvious but i just gotta ask) - how's the fluid look and have ya had the fluid changed? just curious in case there might be crap blocking up parts of the valvebody or something.
