Old 08-02-2006, 05:07 PM
Bravada 97's Avatar
Bravada 97 Bravada 97 is offline
New Tire Question
Hi guys. I am looking to replace the tires on my 97 Bravada. When I bought it used it had 235/ 70r-15 on it. They are fine but looked too small for the wheel wells. I notice even 235/75r-15 looked to fill the wheel wells better and looked better as well. My buddy has a Mitsubishi Montero and it runs 265/70-r15 and these tires look much bigger than mine and fully fill out the wheel wells too, which looks better on an suv in my opinion.
My question is can I run the 265's on my Bravada, and if so will it hurt my fuel economy significantly? Thanks for any info as it is greatly appreciated.
Old 08-02-2006, 05:22 PM
RJ MALIBU's Avatar
RJ MALIBU RJ MALIBU is offline
Re: New Tire Question
you can put 265s on yer truck . as 4 mpg, bigger tire =more weight, more rotation ,poss 1-3 mpg diff
1997 Blazer w/99+front end with clear Euro Projector Headlights and parkinglights and cai 2 -12'' Dual subs 600w RMS 600 watt kenwood amp Sony head unit
2003 malibu-bone stock(wife's car)
Old 08-02-2006, 10:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I run P235/75r15.
Run fine. Just remember when your speedometer says 60mph, you will be going 63mph in real life.
Don't go to a 265 or you will more than likely kill your economy a bit do to more surface contact with the road.
Rolling resistance is never a help.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-03-2006, 06:02 AM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
30x9.5r15 is all you need for the bravada.
Old 08-03-2006, 06:18 AM
blazee's Avatar
blazee blazee is offline
Problem?
265/70 15 will fit just fine. I've had several sets of BF Goodrich Long Trail T/A 265/70 15 on my 98 Blazer. They are a little too wide for the rims, so the side walls bulge a little. The last time that I bought tires, I got BF Goodrich Long Trail T/A 235/75 15. They are only 3/4" shorter than the 265/70, and the set was $100 cheaper. There was no difference in fuel economy between the two sizes.
Old 08-10-2006, 02:28 PM
Bravada 97's Avatar
Thanks for the feedback guys! I appreciate it.
Old 08-10-2006, 11:38 PM
mdrush mdrush is offline
The 235 75s are OEM on some blazers with specific suspension packages...GM will tell you depending on the shocks your truck was equipped with 70's will produce a smoother ride....I had the premium ride package and mine came with 70's Michelin LTX and deCarbon shocks. Long since gone.
Those Long trail are great tires...I had 70K miles on the Michelins with 3 rim leaks....the BFs lasted 110K miles...no flats before a belt started bulging.
Mike
