Body Trouble Codes/Cruise COntrol
HELP! All my PCM trouble codes are ok, buut my BCM of my '03 Stratus SXT 2.4l, says B064f, or some dang thing. Also, the cruise control died. All fuses are ok, relays check out, replaced the brakelight switch.
When the Criuse is activated, the light comes on, then dies out. If it stays on, it will go out when you try to reset it. It will repeat the cycles I described above only after I kill the motor, and park the dang car.
What's up with this BCM? HELP with any trouble codes, and Thank you guys and gals very much.
