Old 08-02-2006, 03:51 PM
n2racing n2racing is offline
87 IROC mass air flow problem
I have an 87 IROC which won't run right unless carb spray is sprayed into the throttle bore.
ECM and MAF don't help.
Any ideas?
Thanks.
For Only Real Drivers
Old 08-02-2006, 04:01 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 87 IROC mass air flow problem
Is the fuel pump running at all?
Old 08-02-2006, 04:03 PM
New fuel pump. Car runs but not well.
Old 08-02-2006, 04:06 PM
wrightz28's Avatar
hmmm, ok, so it will start and run, but run like poo unless you spray carb cleaner, then it runs 'normal' until the cleaner is burned, then runs like poo again?
Are you able to check the fuel pressure?
No S.E.S. light?
Does the car run better when the MAF is disconnected?
Old 08-02-2006, 06:22 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Yeah, I think you should have it scanned and then maybe a tune up if its been a while and definetly check the spark and fuel pressure.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-05-2006, 05:53 PM
SES is on with MAF sensor code. No problem with sensor or wiring. Harness was replaced. No more noxious smell but light stays on. Fuel pressure is fine.
Old 08-07-2006, 09:24 AM
wrightz28's Avatar
I'd be loolinkg at the relays then.
