Old 08-02-2006, 03:42 PM
AmazonSprite AmazonSprite is offline
Tamiya products
A few quick questions about Tamiya spray paint and putty...
What type of primer needs to be used (other obviously than Tamiya's own primers)?
There appears to be several types of Tamiya putty - 'basic', 'quick' and 'fine' - the later two being described as epoxys. Obviously, the 'quick' is quick curing, but otherwise, is there much difference? I've tried Tamiya's own website, but it's no help....
Thanks!
Paul
'67 Amazon 122S B20 o/d Estate & '61 A-H Sprite Mk2 948cc
Old 08-02-2006, 03:56 PM
gasman03's Avatar
gasman03 gasman03 is offline
Re: Tamiya products
you can use any type of laquer primer. it must be laquer though. Like Duplicolor or even Model Master laquer primers work good.
not too sure about the putty though, but i'm sure someone here will give you a good answer
Old 08-02-2006, 03:57 PM
obican obican is offline
Send a message via ICQ to obican Send a message via MSN to obican
Re: Tamiya products
I always use Presto filler-primer as the base coat, since it fills small mistakes and its gray color helps you seeing the mistakes. as the surface is free from all mistakes and ready for color coats, I use tamiya's white primer. if I'm gonna use automotive paint on the model, I use another white primer, which is not acrylic.
of course you can skip that graycoat and use tamiya's white primer as the basecoat.
I don't know about Tamiya's putty, I use automotive polyester putty on my models.
Working On:
C: Chassis, Floorboard, Suspension
E: Engine, Transmission, Plumbing and Wiring, Driveshaft, Differential, Brakes, Tires etc.
B: Bodywork, Paint and Trim
I: Interior
'60 Pontiac Bonneville Coupe (C: 95%, E: 95%, B: 60%, I: 50%)
Ferrari F50 (C: 80%, E: 92%, B: %90, I: 90%)
'60 Pontiac Bonneville Convertible (C: 70%, E: 70%, B: 40%, I: 30%)
BMW Z8 (C: 100%, E: 100%, B: -20%, I: 99%)
'90 Chevrolet C1500 (C: 100%, E: 90%, B: 60% I: 0%)
Old 08-02-2006, 04:12 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Tamiya products
Thanks!
Avoid basic, especially for any structure. Its only decent for filling little dings in putty. Nothing major. Quick type putty cures in 6 hours. Its a two part epoxy putty. Great for body kits, or anything that needs putty or structure. I use it a lot. Especially where strength and adhesion are factors. Fine/smooth type is the same thing. Just takes longer to cure, in fact I just got done mixing up some a few minutes ago. Great stuff. Steer away from the one part putties.
Do a search for my scratch build seminar's for the one on putty if you have any further questions.
-Mike
Old 08-05-2006, 03:45 PM
Re: Tamiya products
Mike, your explanation of the putties is just what I wanted to hear! Thanks everyone - much appreciated!
Paul
