Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 08-02-2006, 01:13 PM
special tool special tool is offline
no spark
87 olds 98 has no spark. ignition module is new and good. turns over good just no spark
Old 08-02-2006, 03:59 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: no spark
Crank sensor or wiring from the cps to the icm.
Old 08-08-2006, 05:31 PM
Re: no spark
no luck with crank sensor and after trying to checkcam sensor the right turn signal stays blinking with the key off. With the key off if you turn the right turn signal on the dash function lights all start to bink and now the engine won't even turn over. Battery is good with good connections. to trouble codes when trying to read the computer. will start to trace the wiring from the computer
