Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 08-02-2006, 07:26 AM
jvbs2173 jvbs2173 is offline
96 Tracker EGR problems
Can you bypass this system in any way and the engine run right? It's nickle , dimeing me to death.
Old 08-02-2006, 07:44 PM
edmcm edmcm is offline
Re: 96 Tracker EGR problems
What kind of problems show up because of the EGR trouble? Ed
Old 08-03-2006, 07:56 AM
I just replaced the catalytic converter but the engine is still loading up, boggs down at low speed ,then picks up as you build up speed. Air conditioner boggs it down as well. Mechanic says it's not EGR related this time. He's looking at it today and I guess I'm grasping at straws.
Thanks
Old 08-03-2006, 06:21 PM
Let us know how it turns out OK? Ed
Old 08-04-2006, 01:23 PM
viperh viperh is offline
Send a message via AIM to viperh Send a message via Yahoo to viperh
take the EGR off and put a block off plate on there route the two vacuum hoses to each other. First thing I do to all my cars is delete the EGR system.
Old 08-07-2006, 03:54 PM
Changed out the TP Sensor, no help. Pin one voltage 5 volt seems to be ok.
Engine still boggs down. Taking it to a different machanic.
Old 08-10-2006, 11:31 AM
Well it looks like a timing belt problem. It's jumper a tooth and made it load up on the bottom end but run ok at the top.
Old 08-13-2006, 08:34 AM
Also check your vacuum lines. I just fixed my brother in laws tracker who had the exact same problem. Timing was 180* off when I fixed it it ran rough down low. The pcv valve was clogged we blew it out with a compressor and there was a vacuum line right next to the pcv valve (carbed motor) that was broken when replaced the motor ran like new.
Old 08-25-2006, 10:30 AM
vipp_06 vipp_06 is offline
Question Re: 96 Tracker EGR problems
i just replaced the complete motor in my 90 model tracker and still have a really bad miss in the idle. I'm wondering if there could be a problem in the vacuum system is there anywhere I could find a diagram of the vacuum system online?
