| N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
maximum hp with b16a ?
what is the maximum hp can i gain during safe boost at the stock internals with the b16a jdm 92-95 my fuel managment is safc2 and 450 cc injectors my turbo is t3/t4e 50 a/r and 50 trim . ?
MY ENGLISH IS NOT PERFECT. sorry for that 1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD 1996 CIVIC 4DOOR EUROPIAN VTEC LS 2003 CIVIC LXI 1999 GOLF 4 1400 CC |
Re: maximum hp with b16a ?
with that management system i wouldn't be comfortable making anymore than 275whp or so....you could push it higher, but if the tune isn't accurate, you risk blowing the engine.
I have a bigger turbo (60trim), bigger injectors (RC550s), and tuned on Crome and Im only making 275whp because i'm worried my car lasting.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
if i buy new turbocharger to be 60 trim instead of 50 trim will i have more power or the 50 trim consider good for the stock internals ?
Screw the bigger turbo get better fuel management and get it tuned by someone who knows what they are doing.
2002 Acura TL Type S 1991 Honda Crx Si |
how much boost will be safe to get that 275 hp in psi ?
and what is the eqution ( relation ) between the psi and the hg ( unite which use in the safc2 ?
don't shoot for a certain hp number....tune on a safe boost level and be happy with whatever power you make...
can you help me how to tune on a safe boost level
it depends on your method of tuning. If i was tuning on a VAFC2 on my B16 w/ a T3T4e 50 trim, i would tune on 8psi and be happy. Now if i could get a dyno tuner to set up a Crome map for me, i would boost 11-12psi and be even happier. It is much more precise to tune on a software system rather than a VAFC or anything of the sort. Either way Hany, you will have some fun
as you know iam from EGYPT . and my country is very poor info in turbo. for exampel iam the only one who install turbo in my city. and i do every thing with my self. and no one chip the ecu here. and its hard to me to chip my ecu. iam afraid to damage it. anyway the safe is good . thanks alot my friend
you can still make a lot of power on the SAFC and if you don't have access to a tuner, then you're stuck using the SAFC. Its not a bad option, it just isn't as precise as a chipped ECU. If you read www.pgmfi.org you can find some good tuning tips so that you can tune yourself....good luck!!
other question please . what about the o2 sensor wideband. i hear that its so important. is that right?
if you want to tune yourself, you have to have a wideband. It reads the Air/Fuel mix...that is what you're tuning....
ok. thank you alot for attention. if i have any problem i will send you.
