Old 08-02-2006, 12:31 AM
6g72tt 6g72tt is offline
Need Some Help A Shifting Problem
well first of hi to all of my 3/S bros, sorry if you cant undestand what im going to try to explain to you my english isnt very good, about a week ago i went for i ride in my car when i was coming back home i decided to step on the gas and let it rip, but when i threw 2nd gear the gear wouldnt get in and the car just went to neutral, then i checked my clutch pedal and it felt normal as always, then i tried to put the car in 1st gear and it didnt get in then tried 2nd gear and nothing so then i saw that my shifter would go like from 1st to reverse even without pressing the clutch i really dont know what the car has thats my problem if anyone can help me out i would really appreciated thanks
Old 08-02-2006, 01:12 AM
Igovert500's Avatar
blue + red light magnet
Re: Need Some Help A Shifting Problem
Hm, hows the clutch, old? original? burnt?
How are the shifter cables. Take out hte intake and MAS and have a friend shift through the gears for you, while you look and see what all is going on.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-02-2006, 01:18 AM
hey man thanks ill do that, well about the clutch the clutch its practically new i had it changed in march or feb. i dont remember but the reason that the clutch is new is because i have my stealth turbo (the baby) and a 240sx (all day car) so i really dont take my stealth out a lot also the clutch work y had it done on the dealer so that really doesnt worries me but as you said ill check it out myself by getting the y pipe and intake off thanks bro, and if the shifting cables are death are they hard to put on back again is that a work i could do myself or a mechanic?
Old 08-02-2006, 01:55 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
most likely shifter cables. same exact thing happened to me after i re-installed tranny (after LSD install). i was racing a friend, went to shift into 2nd and it just felt like mush or pudding. softest, smoothest shift ever, but i never got to 2nd. i just had to ride in 1st all the way back home.
upon inspecting it, my shifter cables had come loose. there's a bracket that hold the cables/linkage down on top of the tranny. somehow a bolt had come loose, or fell out. perhaps i forgot to re-install the bolt. i don't know, but i just secured it with another bolt, and problem fixed.
hope your situation is this easy to fix.
by the way, your english is actually pretty good. by reading your post, i couldn't tell that english wasn't your first language. what IS your first language, if you don't mind me asking?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 08-02-2006, 02:04 AM
hey man thanks hope thats the problem to, about my first language is spanish i live in tijuana mexico so if some off you want to party over here you now who to asked thanks bros
Old 08-02-2006, 10:42 AM
3kvr4's Avatar
3kvr4 3kvr4 is offline
Send a message via AIM to 3kvr4
Your clutch might be slippin see if it needs adjustment or it probaly es tu transmission que ya no trabaja bien
