Old 08-01-2006, 10:43 PM
Carfreak18's Avatar
Carfreak18 Carfreak18 is offline
Send a message via AIM to Carfreak18
Capacitor
when is a capacitor needed,how many watts is liek the limit before your battery starts to drain?
Holland Speedway
Lake Erie Speedway
Tioga Speedway (R.I.P)
Wyoming County Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Many more to come....
Old 08-01-2006, 11:16 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Capacitor
It depends on your alternator output.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-01-2006, 11:20 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Capacitor
Caps are never needed. Upgrade your electrical system an Big 3
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 08-02-2006, 07:48 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Capacitor
If you are a ground pounder (SPL type), Manny is exactly right. If you are an SQ competitor, it helps with that last 5% - so it would be the LAST thing I would add to a system.
Old 08-02-2006, 09:24 AM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
Re: Capacitor
Unless you just think that it is cool to have a pointless usually round tube looking thing in your trunk. Then...I would buy a piece of cardboard and paint it and mount it in my trunk.
1995 VW Golf
Cold Air Intake
Cat delete
Full straight pipe exhaust
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Cerwin Vega Vmax sub
Old 08-02-2006, 06:25 PM
Carfreak18's Avatar
Re: Capacitor
so pretty much another way to solve feeding all the energy is to upgrade ur electrical system and it depends on your alternator?
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 08-02-2006, 08:47 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Capacitor
CAPS ARE USELESS.
let me find the tutorial i found on sound domain.
http://forum.sounddomain.com/forum/u...=5;t=007801;p=
Yes lost of reading, but the 35 your going to spend on 1/0 wire, ring terminals, solder and a fuse holder/fuse will be worth it compared to 100-200 for a decent, i said decent cap.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 08-02-2006, 09:28 PM
Audio Guy
Re: Capacitor
the alternator supplies ALL the energy when the car is running - unless you are pulling so much power that the voltage sags to the battery float level (or lower), which is about 12.5 volts. Then the batteries will supply what power they can until the voltage sags below the cutoff point of the amp.
Adding another battery here will just be another load on the alternator and will not really help ..... you need to look at a bigger alternator if you're voltage is sagging below 12.5 volts or so.
When the car is off, of course the battery(ies) are supplying all the power. If you "burp" your system with the car off, and their are some good reasons to do that, then you will most likely need several batteries.
The big 3 upgrade can help deliver a little more power by lessening the resistance of the power and ground wires. It's a cheap and effective way of increasing the power output of your electrical system. Remember to use good connectors and crimp them tight. Most of the electrical loss is in the connectors.
Old 08-10-2006, 09:25 PM
Integra4200's Avatar
Integra4200 Integra4200 is offline
Send a message via AIM to Integra4200 Send a message via MSN to Integra4200 Send a message via Yahoo to Integra4200
Re: Capacitor
so what would be the best way to keep your lights from dimming? ive upgraded my big 3 im about to get a yellow top will that take care of it? my alt is 120 amps i belive. stock 96 jeep grand cherokee.
96 Jeep Grand Cherokee Laredo
5.2 L 135k miles.Flowmaster muffler/mangaflow cat
I wrecked it about a month ago. damage is the front end passenger side. i have 3 good 80% tread 30" wild countrys bought from les schwab. (4th one poped due to accident.)I also have brand new (still wraped in plasitc) front/rear bumper covers. the grey ones. also a brand new chrome grille.let me know if you need something. it will be going to the junk yard in a few weeks so hurry
Old 08-11-2006, 01:54 AM
Mannyb18b's Avatar
Re: Capacitor
It could...no way of telling bro. Untill you have hooked it up an see if it still dims, if it does, time for an alt upgrade.
Alpine H/U-
CDT EF-61's
NSB-100
Old 08-11-2006, 02:26 AM
Re: Capacitor
I'm showing the stock alt. puts out 90 amps. There is an option for the 120 amp. May want to call a dealer 'n' see which you have. If your jeep has the 90 amp, that would explain the dimming lights.
