| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
not having enough amps.
hi, i am in the middle of getting a system and after doing some calculations for watts to amps i found out that i need at least 250 amps to run a 3k w system but the only high outout alternator i can find is 180 amp is there any way that i can be able to get a 3k watts with this alt
Re: not having enough amps.
What amplifiers are you planning on using and what will they be powering?
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
3000W is alot of Power, 500 is usually enough to rumble ur stomach and do ur head in with a good sub. 3000W, i respect that and i wish you luck.
http://unlimitedspeed.x.am |
depends on how you listen to it. If you listen to it wide open with heavy bass music all the time - then your calculations are probably pretty good. If you listen to more musical material or just burp it, those calcs are pretty much meaningless.
i listen to rap the amp i plan on using is a kicker kx2500. it is rated for 2500 but almost all of them their birthsheet says almost 3k. the sub is 1 kicker solo x
