Old 08-01-2006, 09:31 PM
tjb19 tjb19 is offline
89 Escort GT 1.9
I have a 89 Ford Escort 1.9L HO 5 speed that has 346,000 miles and is still running great. However recently my tach needle has begun to pulsate and read incorrectly. There is also hesitation and getting worse in driveability. How can I correct the needle to settle down? I had into Ford dealership today and they said the tach problem could be in the cluster panel, too expensive to fix! I installed a new TFI module but did not settle down the tach. Engine is starting to buck a bit and it doesn't matter what speed u r at/.
Old 08-02-2006, 08:30 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 89 Escort GT 1.9
Can you tell if the tach is jumping in sync with the hesitation you noticed, or is it somewhat random?
With so many miles it could simply be worn parts on the tach.
If you have the parts or tools handy, hook up a secondary tach and compare readings.
Old 08-02-2006, 09:00 PM
12Ounce 12Ounce is offline
Pull the plugs and give them a close inspection ... do all of them have a bit of white ash on the electrode? You may want to install new clean plugs just so you can watch how they appear over time.
Also check the cables for hi-voltage leaking.
Old 08-03-2006, 08:08 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
if the problem is the cluster then get a cluster from a yard and replace it yourself
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
