Old 08-01-2006, 08:44 PM
alkemist's Avatar
alkemist alkemist is offline
Is this bull? Re:" Ground Voltage Stabilizer "
http://cgi.ebay.com/ebaymotors/GROUN...QQcmdZViewItem
This stabilizer is advertised so colorfully with a bunch of bullshit in my opinion. How can it improve performance, fuel economy and engine response all at once?
Would a 1996 car even need such a thing?
Old 08-01-2006, 09:16 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Is this bull? Re:" Ground Voltage Stabilizer "
you didn't really need someone to say it, but I will.
Its a bunch of bull.
I love this quote "Furthermore it improves electrification performance"
Electrification performance? That sounds pretty impressive!
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 08-02-2006, 11:28 AM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
I bet that thing would just internally short out and blow up your battery. That's all I can see it being good for.
Old 08-02-2006, 12:40 PM
alkemist's Avatar
Yea Im thinking alike... more of a danger to our cars than a benefit
Old 08-02-2006, 06:06 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
"It improves accumulation of electricity performance substantially and the case where electric load increases it prevents powering down"
If that isn't the Kings English, I don't know what is........
Old 08-04-2006, 11:18 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
They have proven that they work with sport compacts. Better grounding will net better power in the end so it is possible. It was like 8-12hp depending on brand, model and car. But this looks like they took random shit and put it together to try to sell something. Its not as bad as the gas line magnets, or the tornado/turbonator/any other piece of shit soda can turned bent sheet metal that does nothing more than swirl the air which does nothing since the engines intake and throttle body create turbulence in the air path.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 08-04-2006, 11:25 PM
AF -Advisor
Originally Posted by pimprolla112
They have proven that they work with sport compacts. Better grounding will net better power in the end so it is possible. It was like 8-12hp depending on brand, model and car..
uh no. It was 8-12Hp depending on how screwed up your car was.
You can not "add" ground capacity to a car unless the ground is fubar'd. If its fubar'd then you should fix it, not add useless black boxes that do something simular
Old 08-04-2006, 11:55 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Looks like 4-5 small capacitors in series...
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-05-2006, 12:05 AM
I should have made that clearer im talking electronic power not engine power. The elctrical system will see a benifit but only from the increase in current it can run through the wires. I cant remembe which magazine but the grounding kits did almost nothing the grounding kits with voltage stabalizer did help but like i said 8-12 well 8 was average more like 5-12hp.
I wouldnt buy it and expect a 1 sec drop off 1/4 mile times or much of a feeling like it did anything. These kits arent complete bs like more of the other junk there selling on ebay.
Cardomain
Old 08-05-2006, 02:03 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
I don't know what sort of car you drive, but mine uses an internal combustion engine.
Old 08-05-2006, 11:10 AM
let me search to see if i can find the article. Im not saying it will be something you will notice. And i do agree it is mostly BS.
But better grounding will help the cars electronic equipment. When im installing any kind of car audio i will upgrade the ground wires. And the power wire from the battery to alternator.
Cardomain
Old 08-05-2006, 12:47 PM
If you have electrical sensors on your engine that report to the ECU (computer) it is helpful to have them all on the same ground plane. As an example, if you have an electrical sensor mounted on an intake tube that is made of plastic or rubber it would have a different ground reference than a sensor that is mounted directly to the cylinder head. The sensor that is mounted to the cylinder head maybe grounded (different ground plane) differently than the ECU. Thus, the voltage outputs from the different sensors would be skewed from what the manufacturer intended--and your engine runs strange.
The sensors are normally grounded just fine from the factory but age does and corrosion takes a toll electrically on the wiring harness.
So it doesn't hurt to interlink the grounds from all the engine components back to the ECU to make sure everything is on the same ground plane.
But this is basically patching up a system that could be fixed by carefully cleaning all the electrical connections in the engine compartment (but it is easier to just run ground straps everywhere).
Old 08-05-2006, 02:28 PM
But all electronics whther mounted in rubber, plastic or metal all get grounded to one common location. The chassis. I wasnt talking in terms of the eletrical sensors. I was refering more or less to the alternator and battery. When upgrading the grounds you give the whole system the ability to run smoother. Voltage spikes are common when anything electronic is turned on a/c, lights, fan. These all draw power with the larger wire you give it less of a chance of dropping voltage by providing a free flow of current.
Cardomain
Old 09-22-2010, 09:35 PM
Andrew84 Andrew84 is offline
Well, all that being said about BS voltage stabilizers, please take a look at this:
http://www.adhoc-tech-sci.com/pd-vs-aa.html
And this discussion between me and a fellow member:
http://www.automotiveforums.com/vbul...=1#post6805246
Old 09-25-2010, 03:14 PM
gremlin96 gremlin96 is offline
hmm i did the same thing on most of the old cars i owned. took about 3 ft of wire and some lugs. just cleaned a spot grounded the motor to the frame and body. it happens over the years the ground wires get bad. so redoing a few grounds puts every thing back on the same ground plane. now does it make more hp, nope, does it save fuel, nope. what it does is make every light bulb and electronic device run a bit better. thats it.
