Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-01-2006, 08:04 PM
LadyCammy LadyCammy is offline
Send a message via ICQ to LadyCammy Send a message via MSN to LadyCammy Send a message via Yahoo to LadyCammy
Engine revs high
Got a 91 Eagle Talon and a 91 Plymoth Laser that both rev high. The laser idles at about 2500 and the talon will be up and down. Anyone else have a problem with the misibitsi engine (sorry bout spelling)? We've taken the engine completly apart and had the engine redone, but still revs high. Any help would be appreciated.
Thanks
Cammy
Old 08-01-2006, 08:11 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Engine revs high
Use the proper subforums.
Have you checked your throttle cable? Make sure its adjusted right.
95 Talon TSI AWD
97 Eclipse GST
Old 08-01-2006, 08:29 PM
Killa's Avatar
Killa Killa is offline
you beat me bro .
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 08-01-2006, 08:42 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Throttle cable, FAIV, IAC, and tps Check them all
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-01-2006, 08:46 PM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
This may be of no use at all but I would have the battery checked. I've had cars that idel higher to produce enough power to keep the car running.
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 08-01-2006, 09:19 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That was probably the most butchered spelling of mitsubishi I've ever seen. It's not even close and if you actually pronounce it out you will understand lol.
I will bet it's the IAC or TPS.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-01-2006, 09:21 PM
blk_srt's Avatar
That would be a problem with the alternator
Mods:
Old 08-01-2006, 10:22 PM
Killa's Avatar
If it was your Idle Air Control ( ISC ), let me know I have one, that I bought off ebay, work perfect. I dont use because my old ISC is still work. $60+s/h, that same price I got from ebay.
GM FOR LIFE !!
95 camaro lt1
Old 08-01-2006, 10:29 PM
Oh sorry bout that. Kinda just skipped on thru. I dont know very much about forums just how to make a topic lol. And yes i kill any word out there as i have a memory/word problem and well even at 26 i can't spell worth didly. But thanks for the correct spelling lol.
What's the tps? This is more my boyfriends car who does all the work on all 4 of our vehicles. But well a great mechanic is horrid at reading lol like i am at spelling. Thanks again and SORRY dont know how to move the thread and dont know where to put it.
Old 08-01-2006, 10:37 PM
What's the tps?
Throttle position sensor
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-01-2006, 11:16 PM
BeZerK2112's Avatar
Thats what we thought too untill we worked all day long and the last thing we checked was the battery, and that was the problem. Try taking out the alternator and taking it napa or checker to have it checked. Take your battery at the same time. Checking is free.
[center]
Old 08-01-2006, 11:50 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
ive heard people saying that on some older models(and 91 is pretty old) the throttle cable will heat up and shrink. this pulls back on the throttle plate and opens it up a little. i'd imagine that over time the cable would little by little stop expanding out to its regular size as it cools down. in any case, make sure its adjusted properly, take off the pipe connected to the throttle body and look at the plate to see if its fully closed. also you could check the biss screw. there are more detailed posts on this site about adjusting the cable and screws and what-not.
simplest things first i guess.
if you cant figure it out get a honda.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 08-02-2006, 12:14 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
The throttle cable on all cars when heated up will shrink. That's why there's play in the cable when cold, but none when warm. It could be too tight, if it was ever removed from the tension brackets. If so, I think this is your problem. On the intake manifold there are 2 bolts that hold the throttle cable onto it. Loosen both of them and adjust the cable so that it's almost fully tight, but still some slack.
The TPS and the IAC or ISC, which ever one, are on the throttle body. There's ways to test these out. It doesn't seem like a constant high idle would be a symptom of one of these going bad. I had both go bad and it surged... but didn't stay constant.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
