Old 08-16-2002, 08:33 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
wtb: carpet
where was that site that had the better deal on carpets, my old navy blue carpet is starting to smell and its getting old hehe...anyone know that site? was it accmats.com or something like that? cause the site wont work
blah
Old 08-16-2002, 10:38 PM
1990civic's Avatar
1990civic 1990civic is offline
the site works fine for me!!!!!!!!!!!!!!
Old 08-16-2002, 11:06 PM
tbk49's Avatar
yea but thats the wrong site, theres another one thats cheaper that im looking for.
blah
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Okay, it's www.automotiveinteriors.com and they actually sell ACC mat products, but cheaper (@ $135). Best deal I've found, was pretty easy to put the new carpet in.
Old 08-16-2002, 11:35 PM
1990civic's Avatar
Is It The Same Material As The STOCK Carpet???? I Personally Think That The Stock Carpet SUCKS, Its Very Hard To Clean!!!!!
thanks
Old 08-17-2002, 12:01 AM
tbk49's Avatar
thanks ci5ic, thats the site I meant I just lost the link...did u order the floor mats? how is it in comprison to the stock carpet and what color did u get? hehe soo many questions just wanna be sure...I live in canaduh so I think duties and taxes are gonna be pricey
blah
Old 08-17-2002, 12:09 AM
ci5ic's Avatar
thanks
Hey man, leave some punctuation for the rest of us!
Anyways, it's not exactly the same, but it's good quality, and if you're having trouble cleaning it, then you should try a vacuum.
Oh, and tbk49, I just ordered "graphite" for mine... sticking with the stock grey look with yellow painted trim pieces.
Old 08-17-2002, 12:19 AM
tbk49's Avatar
do you have any pictures?
blah
Old 08-17-2002, 01:08 AM
1990civic's Avatar
Tha Reply #2
Hey ci5ic You Opinion's Are Not Needed Or Wanted!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-17-2002, 08:37 AM
ci5ic's Avatar
Here's some pics I took during the install:
Old nasty carpet (spilled some battery acid on it, had to neuturalize it with baking soda, looked really bad):
The new carpet, you can really see a difference. This is before I vacuumed all the fuzz off it:
Here's a pic of the two carpets side-by-side. Can you guess which is which? hehehe:
Old 08-17-2002, 08:55 PM
tbk49's Avatar
what kind of condition is your old carpet in?
blah
Old 08-17-2002, 09:08 PM
silver89civic silver89civic is offline
Send a message via AIM to silver89civic
Nice carpet!!! Good job *thumbs up*
How did you installed?
Honda Rules!
http://www.cynoptics.com/tldrivers/1024.htm
Old 08-19-2002, 06:47 PM
ci5ic's Avatar
It's pretty easy to install... Heres what I did:
Remove EVERYTHING from the interior (door sills, seats, center console, dead-pedal, gas-tank/hatch release levers, rear seat bottom, all plastic carpet screws). Then pull the old carpet out... There's a metal bracket that you have to remove from under the center console, and it only gives you about 1.5" of clearance to slide the carpet up under the dash, kindof a pain. Also, to remove the door-sills, you need a Torx T-40 bit, and those bolts are on there TIGHT!!!! My advice is to use a nice ratchet with a cheater-bar, otherwise, you'll strip them out. This happened to me on one of the bolts, and I had to drill it out and get a new one from the junk-yard.
Anyways, once the old carpet is out (and all the old padding), you just lay it on top of the new carpet (line it up as best you can), and using some sort of marker, trace ALL the holes from the old carpet to the new one. When you do this, trace inside the holes so they're alot smaller than the stock ones. This way, if the holes need to be bigger, you can trim them, but if you make them too big, you're screwed. Then, using scissors or a box-knife, cut the holes out of the new carpet, and trim the edges of the new carpet. It's really easy on the parts that don't have the padding, but it's a bitch to cut through some of that padding material.
You may also want to take the opportunity to remove all the sound-deadening material that's in your car (the black tarry looking stuff under the carpet) I heard that it's about 30lbs of dead weight. I didn't do this for 3 reasons: 1, I'm not that anal about my car's weight. 2, It'd be a huge pain in the ass. And 3, I don't want some loud-ass road-noise in my car...
Anyways, then, test-fit your carpet and trim the holes and edges accordingly. Once you've got the proper fit, make sure all your wiring (seatbelts sensors, etc) are pulled through the appropriate holes, vacuum up all the fuzz, and re-install all the interior stuff...
Hope that helps.
WTB: Gray Carpet david-b Classifieds 2 04-11-2007 11:21 AM
WTB: black carpet and/or speaker pods civicunrest Classifieds 0 05-08-2006 08:57 AM
WTB: Rear cargo compartment/carpet/spare tire cover thingy-ma-bob quiXilver Classifieds 2 07-14-2005 09:02 PM
Carpets (front - floor) carpets wet. Peter Solarik Century 2 03-04-2005 08:14 AM
WTB: Carpet for 93Z bulldog95 Cavalier 1 04-30-2004 08:55 PM
