| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Rubber coating on intercooler pipes?
My friend is going to sand blast my hard intercooler pipes to get the powdercoating off of them so I can repaint them. I was looking at paint in his store the other day and he pointed out some rubber coating spray paint. Its used for insulation and such and for painting engine bays and undercarriges too if I'm not mistaken. I figure it would work well to paint them with a thin coat of the flat black rubber coating because it should help to insulate the pipes and block the heat from the turbo, and also give it a cool wrinkle finish. I was just wondering what is your guys input on this? Thank you.
BTW: If you steal my idea, I will hunt you down and kill you.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
Re: Rubber coating on intercooler pipes?
Couldn't hurt, sounds like a good idea! BUt probably won't change too much.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Actually I believe it would do the opposite. By blocking the post intercooler piping off, you're not letting it dissipate heat. Intercooler or not that air is pretty damn hot inside that pipe, you won't let it dissipate. I remember reading an article about this, ill try and find it.
now - 2000 civic soon - 2002 is300
What if I only coated the piping after the intercooler? And if I do this what do I do to the piping before the intercooler?
leave the piping alone imo, it's made to dissipate heat. If you block that anywhere it will only hurt you.
Sounds like a good idea. I'm not sure about heat dissipation, but it would be great for people who live in states with strict law enforcement. Since that would probably give it a more stock look. Keep us updated if you do use it.
the piping isnt made to dissipate heat thats the intercoolers job. the only problem i see is that most undercoating never sets completly hard or it takes a long time to set. insulating the pipes is a good idea though since the underhood temps are higher then the air coming out of the ic. lots of guys wrap the piping in exhaust heatwrap.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
Thanks for the input. I'm pretty sure I'm going to do it. My buddy is supposed to be sandblasting my pipes for me this weekend. So, should have it done and coated soon.
