Old 08-01-2006, 02:23 PM
E.Derrah E.Derrah is offline
2002 ZR2 Changing Headlight Bulbs
I've got a 2002 ZR2 and I need to replace the drivers side lowbeam. How do you get to it to change it? How is the bulb going to come out of the housing?
Your help is greatly appreciated,
Eddie
Old 08-10-2006, 09:28 PM
ssss-10 ssss-10 is offline
Re: 2002 ZR2 Changing Headlight Bulbs
Eddie
There are two black plastic tabs that you have to pull up to release the headlight housing. They are on the backside of the radiator support. After you pull the tabs you have to pull the whole housing out carefully. The bulb will come out by turning the wires and bulb counterclockwise, make sure you line up the tabs on the bottom of the headlight when you put is back in. If you don't get the tabs back in the slots the headlight will not be lined up right. Good luck...
Old 08-10-2006, 09:35 PM
blazee's Avatar
blazee blazee is offline
Problem?
Welcome to the forum guys.
ssss-10 is correct. Another member was nice enough to take a picture. Click here to see it.
