Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-01-2006, 11:35 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
rebuilding the 7 bolt
This is what I want to do. I cw'd and I want to stroke my motor, but if I wait untill next summer I can do it in school and have professional help and the school will pay for some of it. Also when I told my parents its going to be $2k for just the engine they kind of freaked out. That said I want to rebuild the 7 bolt just so it will last untill next summer(I dont drive it in the winter) Do you think I can get away with remanning the crank and replacing th bearings? I know you never know untill you measure it but I though maybe someone else tried it. The other option is my parents said that they would give me an early birthday and xmas present and pay for my to build a stroker but then I'll need a clutch and flywheel and everything else to do the 6 bolt swap so I think its better to wait
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 08-01-2006, 01:35 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: rebuilding the 7 bolt
Well you can just buy a new crank. They aren't that expensive. The thing about 4g63 cranks, is no one machines them because when you machine a crank or remann it it degrades the quality of the crank. It's common to do this on big block V8's because the cranks are much more expensive. If I were you I would just buy a new crank. They are inexpensive.
1991 GSX 2.3 Stroker
Old 08-01-2006, 01:48 PM
blk_srt's Avatar
Any idea where I can find a cheap crank?
Mods:
Old 08-01-2006, 02:51 PM
pnkrocker4life pnkrocker4life is offline
go to machv.com.......look on the left side of the page under engine and scroll down, you'll see mitsubishi OEM crank(7bolt). thats where id start....its 600 bucks though. depends on if you wanna spend that much or find one in a junk yard
-1997 Eclipse GSX-
bushcur 2.4 long block
buschur racing head
buschur BR500 turbo at 25 psi
unorthodox ultra G kevlar clutch
sieman deka injectors 650cc
apexi N1 turbo back exhaust
--other stuff as well....too much to list
481 AWHP
422 FT/LBS
1/4- [email protected]
1/8- [email protected]
60ft- 1.778
Old 08-01-2006, 03:14 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Ever think about stroking the 7 bolt?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 08-01-2006, 04:02 PM
blk_srt's Avatar
Yeah I have thought about it, and I was strongly considering it at one point but I figured that If I'm going to spend that much money I might as well not take any chances
Mods:
Old 08-01-2006, 04:07 PM
MexRocket's Avatar
MexRocket MexRocket is offline
look at ffwdconnection.com they have the best cranks for pretty cheap I think.... well, the butcher crank for the stroker is fucking crazy.... check them out...
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 08-01-2006, 04:27 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
did you ever verify 100% it has walked?
now - 2000 civic
soon - 2002 is300
Old 08-01-2006, 04:35 PM
defiancy's Avatar
I bought mine from a local shop. It was no where near 600 dollars. You can check junk yards in your area, you can probably find a good crank there.
Or if you have any DSM shops in th area they probably have one.
Old 08-01-2006, 04:59 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Why waste money? Junk the 7 bolt and do up the 6 bolt. Hey Scott, want to start our own car club?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-01-2006, 06:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
New bearings and a reman'd crank should get you up and running until you want to build up that 7 bolt. Just make sure you go to a shop where they know what they're doing. I've had a couple cranks ground before and they turned out just fine.
95 Talon TSI AWD
97 Eclipse GST
Old 08-01-2006, 07:39 PM
blk_srt's Avatar
Endplay was close to .020 and according to what I've read the max is .015.
Thats good news. I should be up by the end of the month then
Mods:
Old 08-02-2006, 02:15 PM
blk_srt's Avatar
I just got back from the machinest and he suggested that he weld material on the crank and reharden it and then grind it down to stock size so I can use standard bearings and it will be a hardened surface again and its going to cost $175 for all of that plus bearings
Mods:
Old 08-03-2006, 03:37 PM
defiancy's Avatar
My shop is a dsm shop and I asked them about this, and they advised against this, but it's your buck.
Old 08-03-2006, 06:39 PM
blk_srt's Avatar
What do they reccomend besides a new crank?
Mods:
