Old 08-01-2006, 08:35 AM
briltype briltype is offline
car elec. cuts out
Hello all,
heres my prob.
everything works fine all elec works great!
but whenever I turn the A.C. on it works and every now and then will shut down the whole van down to the radio resets too.
anyone know what or where the bad ground would be?
thats what I'm thinking anyway
thanks
Old 08-01-2006, 11:29 AM
busboy4 busboy4 is offline
Re: car elec. cuts out
Hi,
If you want to start simply: I have been amazed over the years by how a little corrosion buildup on the Battery terminals can cause big problems. I have also seen on my '96 where a slightly loose cable at the battery produced similar symptoms as you describe, however with my van, the entire vehicle would go cold, then snap back.
Old 08-01-2006, 01:13 PM
samething LOL I just sat there and let the van run at 15-20K rpm with a/c full ,
note fans kicked in and out but no cut off ran fine so thats got to tell me theres a ground thats bad somewhere.
New Bat
new alt
where does anyone think that ground would be?
thaks all for the help
Old 08-01-2006, 08:34 PM
wiswind wiswind is offline
You could have a bad ground OR power connection.
The best way is to start at the A/C compressor and work back to the battery and also the alternator.
I have read posts about corrosion at the starter connections, but usually one has problems starting.
ON the 95 & 96.....I don't know what year they moved all the relays into the relay box in the engine compartment....
The A/C compressor gets power from the CCRM (Constant Control Relay Module) which contains relays for the A/C compressor (PCM drives these relays), Radiator fan High and Low speeds, and the fuel pump.
I have pictures of the CCRM in my pictures that the link in my signature takes you to.
Relays can be very picky about the voltage at which they will work....so corroded connections can cause some strange problems.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
