Old 08-01-2006, 02:03 AM
cory fincher cory fincher is offline
fuel issue
hey guys i am leaking fuel very rapid from my fuel line at the bleeder vale the vale stem looking thing on the line it got pressed by acident and now leaks badlly any help appreciated i dont know if when pushed it broke or is stuck thanks
Old 08-01-2006, 09:46 AM
12Ounce 12Ounce is offline
Re: fuel issue
You can get a valve core tool from most aftermarket shops. Try removing and reinstalling the core to see if the leak stops.
If not, you can next buy the whole valve as a replacement from Ford. Be sure to use some teflon tape on the threads when installing. 10 mm wrench if I recall.
Old 08-01-2006, 12:02 PM
Re: fuel issue
thanks man i will try that
Old 08-01-2006, 01:15 PM
Re: fuel issue
hey there i just pulled out the core and put in a new one now its great thanks alot man, even though i lost $15 bucks in gas im glad its fixed
Old 08-01-2006, 04:46 PM
Re: fuel issue
I'm glad you got it fixed before having a fire!
.. also glad you realized that you could buy a new core. I intended to include that bit of info, but just forgot to. Just make sure its one that has gasoline resistant components ... not just for bicycle tires.
