Old 08-01-2006, 02:30 AM
jmj_camaro jmj_camaro is offline
electrical nightmare
i have a 94 camaro. when i first got it it ran great but four days after i got it i spun a bearing yeah i know you dont got to tell me. but being the camaro loving gear head i am i decided to rebuild the engine and after about a month of work i put my nice new engine back in. i was so happy. after i got everything back in place i tryed starting it. and it started up just fine but it ran rough and it had a loopy idle and would die. so i played with it a little and got it running ok but it would still die or it would go from running ok to rough to loopy to ok and then die for no reason. when i would drive it it would drive ok but then run rough or die. and when it would die it was like someone just turned it off. no stall or nothing. just like someone cut the power. but it would start right up. and sometimes it would shift into gear hard and not shift until a high rpm. if i turned it off and then started it it would be fine. when i ran a diagnostic machine it read that signals where low to the throttle position senser and the distributer and something about PROM error i tryed replacing the distributer and the tps but it didnt nothing besides hurt my wallet so i stopped driving it until i could figure out whats wrong. someone said i could restart the comuter or something. i dont know what to do. HELP ME!
Old 08-01-2006, 02:05 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Re: electrical nightmare
As far as the lopey idle, are you sure the plugs are gapped right? One time I mashed the electrodes on 2 when I put hem in and it ran real lopey and would stall out.
As far as the computer thing... wait for Dylan or John - WrightZ28 / FormulaLT1, they'll know what you should do.
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 08-01-2006, 05:16 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Just so we are on the same page here. This is a LT1, right?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-01-2006, 05:48 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
You didn't install the cam too far advanced or retarted did you?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 08-02-2006, 10:25 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Quick abrupt death = electrical/igniton failure.
First thing I would do is make sure that all the grounds are on and snug, didn't receive any damage during the swap. etc. The fact the TPS is throwing a low voltage code is where I would start from.
Old 08-05-2006, 01:36 PM
yes this is an lt1 and no i didnt advance or retard my timing and i did have a very bad ground that i discovered shortly after writing that message and i put the biggest ground possable on it and that made it run a lot better but the tps is still messing up and it doesnt loop but the idle will go back and forth every so often and i dont know if i mentioned this in the last one or not but sometimes when i shift it into gear it will hit HARD and wont shift until almost 4000! but if i pop it in nuetral and turn it off. then turn it back on it will go back to normal. i thought maybe the tps had something to do with that. should i try to replace it even though when i had the diagnostic ran on it it said the signal was the problem? i should have just restored my 67 camaro !!!!
