Old 07-31-2006, 11:16 PM
arodg25's Avatar
arodg25 arodg25 is offline
obd0 injectors
i've got a 1990 jdm crx with the b16a im having trouble with aircare and am wondering if i can switch the injectors with the ones from my sohc zc, there both obd0 and both use the resistor box, any idea?
Old 08-01-2006, 12:10 AM
anthony90si anthony90si is offline
Re: obd0 injectors
ya pretty sure i used my d16 ones in my b18a!
stock b18a1 14.97 @ 92 mph
Old 08-01-2006, 12:11 AM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: obd0 injectors
yeah they should be able to work. i put my obd0 d16a6 injectors in with mine and they work fine so i would imagine the zc's would work. whats wrong with the other ones?
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 08-01-2006, 12:41 AM
arodg25's Avatar
Re: obd0 injectors
im not sure that there is anything wrong with the b16 ones but my civic just passed aircare a couple of months ago and i heard that the #1 cause of hydro carbons was bad fuel atomization, like a squirt instead of a spray. so i might as well change them with something i know works perfectly.
Old 08-01-2006, 01:03 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: obd0 injectors
If it aint broke, dont fix it...
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-01-2006, 01:23 AM
crx2034 crx2034 is offline
Re: obd0 injectors
i just bought a 91 jdm crx sir and i had problems passing emissions( i think the same as aircare, i live in arizona).First time,Failed. I changed the catalytic converter, new plugs and had the fuel pressuer checked and all ignition items checked, failed. #rd time changed ecu to 91 usdm crx HF and added some "guarenteed to pass emission" stuff in my car,Failed, however i did not run all of the tank of gas out and put a fresh tank like the instructions said. 4th time i had a fresh tank of 91 octane gas and a 90 or 91 integra ls ecu, PASSED with flying colors. ALL my readings were WAY down. Now i have to get a new windsheild and a level 3 inspection and hopefully i can get some plates.
Old 08-01-2006, 01:49 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: obd0 injectors
-tony-
2000 honda s2000
Old 08-01-2006, 01:59 AM
FrodoGT's Avatar
Re: obd0 injectors
Of course the old standbys..
If it aint broke, fix it till it is! And the primary tools= WD-40 and duct tape....If it doesn't move and it should..WD-40, if it moves and it shouldn't...Duct tape
Current project:
Rio Red 91 hatch.
