Old 07-31-2006, 08:15 PM
TheDeal526 TheDeal526 is offline
Radio Display and Dash Lights
I just got my 1993 LeSabre, and I noticed the dash does not light up and there is no radio display (factory radio). I think its a fuse. Can anyone tell me where I would locate the fuse box? Or can anyone tell me what else may be the cause of this problem?
Thanks!!!!!
Old 07-31-2006, 08:42 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Radio Display and Dash Lights
A faulty fuse does sound like a good place to start. I believe the fuse box for your year is in the engine bay, along the firewall on the drivers side. I'm not totally sure on that though.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 07-31-2006, 11:16 PM
spinne1 spinne1 is offline
Thanks!!!!!
Firstly, check that the interior light slider is not all the way to the left, which might cause that condition. After that, the fuse box is below the dash near the driver's side wall. To lower it, squeeze the two pieces of plastic sticking out in front of it and it will swing down. Then when you want to put it back you squeeze the same plastic, swing it up and it will lock into place.
As for your fuses, they are all marked on the inside of the fuse box cover. I can't remember the fuse number exactly.
If neither solution works, report back.
