| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
blow off valve for intake
i have a 92 protege DOHC with cold air intake,headers,performance pistons,cams ect..... would a low psi blow off valve work to realese the loud gurgle out of the exsaust. my air flow meter is from an rx7 and it produces a lot of air flow. i sound like a loud mustang!!!!thanks
Re: blow off valve for intake
![]() you need to put a potato in your exhaust first...it'll make it faster too!
life begins at 10psi of boost Three turbo'd motorcycles and counting.
Blow off valves are only for turbos, not intakes.
![]() Unless you're one of those people who want to get a fake blow off valve? Just for that "turbo sound". |
i dont care about the sound of the bov. i just want to put the excess air to good use
If you are looking to redirect exhaust flow, then you don't want a BOV, you want a waste gate....but its the same thing. If you have excessive exhaust pressure, then you have a plugged muffler. There should be no notable pressure on the intake or exhaust without a turbo anyway.
is there anything else i could do
there's lots and lots of things you could do. Try to be a little more specific on your desires. We'll try to be specific on the answers.
If you just want a loud PSST sound....get a turbo.
ok. when i hit the gas i can hear the intake suck a lot of air in. i can hear it over the exsahst and my radio. it almost sounds like a bov. but anyway, would this be why my exsahst gurrgles so much.
Thats generaly a good thing, it means its working
Thats because you have no baffling on the intake. Put the stock airbox back in and it'll go away. As for the "gurgling" in the exhaust, its caused by two things mostly. Exhaust leaks and extremely low back pressure. Most likely its an exhaust leak.
A) gurgling could be from too little backpressure as said above. You mentioned you have a header. Do you also have a catback, how wide is hte catback and muffler?
B) You mentioned you have an rx7 MAF, are you running any kind of piggyback or anything to tune the ECU, or are you relying on the stock ECU to learn how to deal with all of these mods on its own? How about a full mod list.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
this is one of the dumbest threads ever...
Rob
well that's not going to help him. yes, he started off asking some questions about stuff that he had no idea about so we're trying to help him. instead of just saying "this is stupid" why don't you help someone out. i bet there's a shitload of stuff you know nothing about, you want to learn about it, you wouldn't if everyone here was like you. grow up and stop acting like you own the world.
anyways, if you put a bigass fart can (one of those big mufflers) then that's your problem, put a better muffler on it. if not it could be an exhaust leak, do you smell exhaust inside your car? there isn't much that you can do without replacing some parts, you CAN buy some of that exhaust tape and that might bandage it for a while but it's not going to fix the problem and you'll just end up using that stuff again. if you feel confident enough, replace some exhaust parts, lots of aftermarket exhausts are bolt ons so you don't need to so any welding. find the hole and see what parts are available, decide wether or not you want to fix it yourself or bring it to a mechanic.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them. Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood. On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear. |
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
do u show up to a lecture without any prereading and expect the professor to answer ur stupid questions? learning is a two way experience, if you don't put in any effort, others won't either.
Rob
