Old 07-31-2006, 01:34 PM
Dbcurtis Dbcurtis is offline
Blower has failed again - 2000 Grand Am
Here is what is happening:
On initial start up - blower works fine A/C or Heat
After running for about 2-3 minutes is slows/near stops. (set on 5, hardly anything coming out the vents)
Switch all climate controls to off for 5- 10 min
Repeats
Have tried kicking (lightly) the shroud under the dash, wham comes back on for a few minutes.
Is this the blower resistor (again)? I replaced one about 5 years ago, what a PIA.
Old 07-31-2006, 05:22 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Blower has failed again - 2000 Grand Am
When the resitor is bad it only makes the first two settings, 1-2, not work.
3-5 usually work when this fails.
Could just be a loose plug-in on the blower motor(from kicking it ) or the blower is starting to die.
Pretty easy to take that panel off and look to see if those two different plugs are a go.
Could also hav something in the blower housing, stoping the squarrel cage.. but not likly.
1999 Grand Am SS 3.4 OHV
Old 08-01-2006, 10:40 AM
Is the blower somewhat easy to remove and replace on this vehicle?
I have not been under the dash of this vehicle in quite a while.
Old 08-01-2006, 12:21 PM
Sure is easy
Thiers three bolts/screws that hold the kick panel on over the passengers feet area.
Thiers also three screws holding in the blower motor.
- Think these bolts are all 7mm or 5.5mm
Old 08-01-2006, 01:08 PM
Thanks for the info!
Just picked up a new Blower w/cage at the local auto parts store
Will be installing tonight
Old 08-01-2006, 03:10 PM
Night would be Much cooler,
gets kinda warm standing on your head
Old 08-03-2006, 01:34 PM
Made the change, not difficult at all. Just requires a little patience and persistence. Oh yeah, an appointment next day with the chiroproctor (sp?)
Old 08-03-2006, 08:04 PM
I heard that !!
