Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-31-2006, 01:33 PM
thepyrofish thepyrofish is offline
Unhappy It simply won't run right... **Progress**
OK. I'm trying to get my car(the one in my sig) to run properly. It's stuttering. By stuttering I mean constantly, sounds kinda like a miss I'm not sure. It does it at any RPM, but I don't know if I lack power or not. Car was off the road for storage so I won't be able to drive it until I get it running.
I've tried zeroing out the Maf Translator and retuning it using instuctions online, and I can tell I'm doing it right because the car is responding and improving when I do it. That miss is simply everpresent. So far, my list to try is:
Boost leak test, did one before it went into storage for the summer, but I'll do it again.
Reset BISS, I'm sure I've messed with this at some point.
Check plugs, wires, etc. Not really familiar with the Talon's Ignition system so I may as well learn it now
I have a fuel filter lying around, and I'm sure that needs to be done so I'll change it too.
EDIT: I'm also going to doublecheck the timing...
I have a datalogger, but the palm pilot is a piece and doesn't work right so I can't use it. I'll be getting a new one, but it won't be here right away.
Is there anything I'm missing here? I miss my fast car and people are starting to doubt my mechanical ability The car was running a little rough for a bit, then one day it started doing this. If anyone has any ideas, suggestions, or advice please let me know. I need all the help I can get.
1994 Talon TSi FWD
6 Bolt Swap, Big16g (450cc injectors, dumb previous owner), 3" MafT, Blitz BOV, 3" Exhaust (Stock DP, again the PO), ACT Clutch (not sure which, came with the car)
Future Mods
FOR SALE!!! Motor has less than 80 000kms, just needs a few pesky internals...PM me. Pretty please?
Old 07-31-2006, 02:51 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: It simply won't run right...
What plugs do you have in it and at what gap?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-31-2006, 03:03 PM
To be honest, I don't know. They were nearly new when I bought the car so I haven't changed them yet. I know better than to trust a PO on anything, but I was lazy. I am going to work on the car this evening so I will check that as well.
1994 Talon TSi FWD
Future Mods
Old 07-31-2006, 03:15 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Make sure you have a dealer timing belt.
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 08-01-2006, 03:06 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
That really isn't such a big necessity, it's just something that some people like for a preference. I've done many timing jobs on aftermarket belts and not a single one has come back faulty yet.
Pyrofish, what are your compression numbers?
95 Talon TSI AWD
97 Eclipse GST
Old 08-01-2006, 10:56 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Are you missing at when ever the car is on? Or only durring WOT?
DSM geek
Old 08-01-2006, 11:58 AM
MexRocket's Avatar
MexRocket MexRocket is offline
or have you checked your wires to see if they are grounding somewhere else? If they have a resistance over like .7 or something.... you need new wires, and could cause what you are saying. I had wires with a resistance of 5.0 yes... fucking 5 fixed the problem with new wires
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 08-01-2006, 03:40 PM
Ok, I got busy helping my dad with some things so I didn't even touch the car last night. I'll get to it this afternoon though. I have to go borrow a compression tester and I need a ride from my sister. I hate being car-less.
Oh, and it misses all the time. From idle to redline, regardless of throttle. I'll get back to you guys later today, and thanks for all the help so far.
1994 Talon TSi FWD
Future Mods
Old 08-03-2006, 03:00 PM
I may have something here...
These are the plugs, in the same order as they were in the car. 1 and 4 melted!
They are the BPR6EIX NGK Iridiums. The NAPA in my litle podunk town only had 3 6ES in stock, and didn't carry the 7ES. I ended up replacing them with cheap-ass AutoLite plugs.
I also found 2 more leaks, nothing major, and sealed them up (one was my boost guage...yet another thing that I need to re-install correctly )
I don't know if any of this fixed it, however, as my battery is dead and my Dad's battery charger blew up last week. Nobody is around to boost me. Figures.
I also made sure all the plug wires seemed ok and were attached solidly. My multimeter seems to have been misappropriated, so I haven't checked resistance. I haven't reset the BISS or checked timing because I can't start the car yet...
I'm staying optimistic and hoping it's good now, but with my luck it's as bad as ever. I'll post again when I've got it started.
1994 Talon TSi FWD
Future Mods
Old 08-03-2006, 03:42 PM
Wholly shit...but that was about what I expected lol.
Should have just replaced them with the 6es instead of shooting yourself in the foot once again and buying the *cough* Autolites...might want to take them back before running them and exchange. Make sure you gap them.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-03-2006, 04:31 PM
Yeah, NAPA called me a half hour later 'cause they found another case of the 6es. So I returned the other ones and bought an extra set. Gapped at 028 and waiting for someone to come home and boost me First stop, new battery.
Cross your fingers, boys...
1994 Talon TSi FWD
Future Mods
Old 08-03-2006, 05:46 PM
DOMS's Avatar
DOMS DOMS is offline
Okay, I'm no mechanic (yet!), but isn't the reason why they burned important?
I'm not sick, but I'm not well.
1997 Base Eclipse, stock.
Hey, I'm just getting started.
Old 08-03-2006, 06:32 PM
Yes. Yes it is. From what I read a little bit, we run the 7es instead of the 6es when we start to mod because it handles heat better? My car was probably knocking its ass off when my friend ran 87 in it too, so it may have had something to do with that. I'm going to look into it a bit tonight, as well as reading up on cams. Yay.
EDIT: Got it started. Still missing, still pissing me off. If the sparkplugs didn't fix it, and the rest of the ignition checks out, I'm assuming the melted plugs were a symptom and not a problem. Goody. I hope to check timing tomorrow.
1994 Talon TSi FWD
Future Mods
Old 08-04-2006, 12:26 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Did you check to see if your coil pack is bad? And running 87 octane in a turbo dsm is a horrible idea. 92 and higher is the safest thing to use.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 08-04-2006, 04:00 AM
Yeah, I always run 91 or 93 depending where I'm getting gas. He only put in a quarter tank or so, so I drained most of it and made him put premium in it.
I'm short in tools at this house, 'cause I have no garage. I'll be getting a timing light and a multimeter (still can't find mine damnit) tomorrow likely, so then I'll be able to do some more. I'll just assume I can find instructions on testing the coil pack if I search around. Every other damned thing is online...
1994 Talon TSi FWD
Future Mods
