Brake pads
Does someone can show me how to change the brake pads of my 96 Camaro RS?
I did change the pads before for my other car. But when I removed the wheels of the Camaro and tried to loose the nuts of the Caliper, I only found two holes, where the nuts are supposed to be there. Thanks. |
Re: Brake pads
Log on to autozone's site and create your own account. then they have a section with vehicle repair guides ready at the waiting.
Re: Brake pads
Thanks for the information. I did that. They said "remove the caliper and then...". But I did not figure out how to remove the caliper.
Re: Brake pads
The front caliper?
Re: Brake pads
Yeah. I was trying to find the two bolts. But only found two holes.
Re: Brake pads
Bolts are from the backside of caliper
Re: Brake pads
I knew that. I changed the pads of a Mazda before.
Appreciate your patience and time. Quote:
Re: Brake pads
Ok,
So if you're loooking down at the caliper, towards each end do you see the slide bolts at each end? I don't doubt your ability, I am jsut praying this car hasn't been driven around with no locating bolts
Re: Brake pads
They are probably torx or hex head bolts in there. My s10 had those and so did my tempo(had both torx and hex
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
Re: Brake pads
Re: Brake pads
Hi Kahjdh,
I think that may be the case. I will buy a set of torx and hex. Thanks a lot. BTW, thank WrightZ28 for the help, even though I did not provide very detailed inofrmation. I'm very grateful for all the help I got from those warm-hearted mechanic genius in Camaro Forum :-). Quote:
Re: Brake pads
I bought a set of SAE Allen wrench, and replaced the brake pads successfully.
Re: Brake pads
they wont be nuts, your probaly feeling an allan hole, or a torx, not sure on a camaro, its either a 3/8" allan, or a torx bit(not too sure on size)
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
Re: Brake pads
oh crap, read a bit further and seen that you found the answer, sorry!
Re: Brake pads
I found on the aftermarket calipers i used they are mostly t-25 or t-30.
