Old 07-30-2006, 11:44 PM
Flash56 Flash56 is offline
91 cavalier heat up problem
I got a 91 cavalier that runs great for around 10 minutes and then it just shuts off because it's not getting any spark, if you leave it sit for a few hours it starts fine and will run for another 10 minutes, no more no less, replaced the coil packs and coil module, have no idea what else to try, a little help would be appreciated.
Old 07-31-2006, 06:14 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: 91 cavalier heat up problem
Sounds like an iginition module going bad.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 08-05-2006, 02:35 PM
the coil module and the ignition module are the same part, i already replaced it, there's something else that's wrong with it that i have no idea what it is.
Old 08-28-2006, 03:10 PM
17ford 17ford is offline
i had a similar problem w/my 91 z24. i'd check your crank sensor and if thats ok check the wire that runs from the crank sensor to the ignition module it could be shortin out.
