Old 08-16-2002, 05:14 AM
91hondaguy 91hondaguy is offline
coolant leak
hi,
i have notice some coolant leak below where the belts and alternator is on my 91 civic. i dun think it leaking from the rad. Some body told me its teh water pump that is leaking. i was wondering if that is true and if i was gonna replace it, wut else do i have to replace.
thank you
i own a 88 yellow CRX
www.northwestshowoff.com
Old 08-16-2002, 05:21 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Sounds like the water pump alright based on location.
Being someone who has experienced the joys of coolant loss from varios parts, I'd suggest replacing all your hoses and thermostat at the same time.
If the pump is going, there's a chance the hoses are getting old - ever seen how fast a raddiator can drain with a pinprick hole in a heater hose etc? Damn fast
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 08-25-2002, 02:40 AM
BullShifter's Avatar
Its your water pump. It's located under the timing belt cover. You better get that repaired before your t/blet snaps from the coolant. Replace your belts, water pump, & timing belt when you have the job done. @ my dealer we charge $450. $365 for timing belt only, so it's worth it to do the whole job while your in that area
:bonghitte :bonghitte :bonghitte :bonghitte
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 05:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 07:43 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 11:20 PM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
