Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-30-2006, 06:33 PM
jclgodale3 jclgodale3 is offline
Fuel gauge floats...
Daughters 92 Rodeo. Driving down the road, the fuel gauge needle floats up and down almost a 1/4 of a tank. Something wrong? A fix for it? Gotta stop to know how much fuel you have?
Old 08-04-2006, 12:17 AM
Re: Fuel gauge floats...
No one else has had or seen this problem?
Old 08-04-2006, 04:09 AM
Paul A Paul A is offline
Hi,
It's pretty much a standard feature I'm afraid.
Both my Rodeos (2.2 petrol, 2.2 diesel) do this.
Going up or down an incline and the needle moves quite a way, and on braking and acceleration!
On a straight,level road at a constant speed it's fairly accurate.
Old 08-04-2006, 08:36 AM
Ramblin Fever Ramblin Fever is offline
Same here; mine floats mainly going uphill - has done this since new 9yrs ago.
Put a bottle of techron in there, but I doubt that'll help. Just the nature of the beast.
For example, normally my truck is just barely coming off the full mark with 60 miles or so, well, when I hit an upslope, or specifically an uphill circular on-ramp, the gauge will read 3/4 full, but when I level back out, it goes back up to full.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-04-2006, 10:50 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
I don't think that's what jclgodale3 is referring to. I think he may be experiencing the needle bouncing up and down (at least that's what it sounded like to me). Could be a bad connection at the sending unit combined with the vehicle vibrating as it moves down the road which is resulting in the needle "float". You can try removing the connector and looking to see if there is any corrosion or oxidation or lose pins. Putting some dielectric gease in the plug before you reconnect it may help but if there is significant corrosion or a loose pin you may need to replace either the sending unit or the wire harness.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 11-27-2006, 07:33 AM
isuzuarrggghh isuzuarrggghh is offline
Exclamation Re: Fuel gauge floats...
I have a 00 rodeo and when the fuel gauge reads approx half or less the dummy light says I need fuel even though I don't. also the engine starts acting funny. any ideas?
Old 11-27-2006, 04:22 PM
Check out the FAQs.
2007 Honda CR-V
Old 11-29-2006, 04:15 PM
with mine the fuel gauge does not "float". i've checked them and can't find anything. I just replaced the pcv valve (it was org over 100k). next to replace is fuel filter. also tried an additive (stp fuel system cleaner) waiting for the wife to come home too see if it worked. tonight unhook the battery and going to try that.
Old 11-29-2006, 04:21 PM
also all the others say fuel gauge "float" mine is not "floating" the needle is okay it is the engine or fuel tank issue and I can't figure out which. I plan on trying everything without having to drop the fuel tank and replace the unit.
Old 11-30-2006, 01:41 AM
AWILLIAMS64 AWILLIAMS64 is offline
I was having this problem w/ my 01 passport, guage going up and down and gas light coming on at random, and it was the sending unit in tank. I got the part from a person on this forum and replaced it saturday and it has been working great! The fuel pump is actually a delco fuel pump and so is the sending unit. My pump actuall had delphi stamped in the top of it and we had a fuel pump from an s-10 blazer out and they looked exactly the same and had the same numbers on them??? All in all this fixed my problem
Old 11-30-2006, 01:32 PM
thanks I will give that a try.
