Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-30-2006, 06:35 PM
ttrout ttrout is offline
02 Envoy Dies while driving down the road
Background. Had a problem with car going out of gear while driving down the road. If you switched to auto 4wd after you stoped it would go just fine.We replaced the switch and it worked fine for 6 mo. Happened again while on the road so switched to auto 4wd and on I went. After driving 400 miles the engine just dies. I coast to the side of the highway, turn everything off and try to restart the car. Turn the key and nothing. Wait a couple of minutes and it starts. I take off but it wont shift out of first so I pull over, turn off and restart. Take off again and it shifts into second but that is all. Repeat the procedure and it works fine considering. Now the abs and parking break light come on and the message board reads service breaks. Will not run in 2wd, noise from transfer case. Codes say to replace some break components to the tune of $900 plus, but that doesnt address the other problems. Any ideas short of junk yard
Old 07-30-2006, 07:24 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 02 Envoy Dies while driving down the road
Yes have it checked out by a tech who is familiar with theses trucks, some of the symptoms point to a bad ignition switch, but proper diagnosis is required. Transfer case may be a seperate issue, but start with the electrical problem.
Old 07-31-2006, 01:56 PM
Service dept changed that out last week after I sugested it. Unfortunatly it didnt help.Forgot to mention external temp is stuck on 50
Old 07-31-2006, 05:00 PM
A990 racer
Start looking for bad grounds there are some on the engine there is one under the center of the dash check, em all out.
Old 09-13-2006, 06:31 PM
Update on repairs. Replaced temp sensor cured the outside temp reading stuck on 50. New pcm fixed the brake message and speedometer problem. New encoder motor on transfer case fixed shifting problems. Alls well except for the outside mirrors ,and now we sell. By the way the pcm was covered under the original warranty, 70000 mi.
