Old 07-30-2006, 04:53 PM
thinmints thinmints is offline
carpet removal 96 xj
Has anybody ever replaced the carpet in there jeep? other than taking out the seats what do i do to get the consule out? thanks for any help you may be able to provide
Old 07-31-2006, 11:19 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: carpet removal 96 xj
Replacing carpet is a lot of fun (at least it is not greasy). I use to work at dealers on Jags and Mazdas. Yea, the seats and every thing has to come out.
First, make a lot of room in your garage. Take out all the seats.
The console: a. take off the shifter handle; b. pull up the shift cover; disconnect wires as needed; c. remove center glove box cover; d. remove screws at bottom of the glove box; e. remove screw holding front of console; f. remove anything else (I can't remember any more, but you can take it all the way out).
You might want to loosen all the plastic or remove completely the rocker panel covers.
Also the two front kick panels on the sides, over the fuse box on right.
Old 07-31-2006, 11:47 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
There should be a number of screws holding the console in, once you've gotten them and the console out, it should be pretty easy to see/remove the carpeting.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
