Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 07-30-2006, 04:35 PM
68sschevelle 68sschevelle is offline
68 chevelle no spark
Hey has anybody seen this one on my 68 chevelle I know the coil is good but I cant get spark, key on 12 volts, key to run 12 volt I pulled the high tension lead put it close to ground - nothing -any ideas
Old 07-30-2006, 04:53 PM
maxwedge maxwedge is offline
A990 racer
Re: 68 chevelle no spark
Welcome to AF. When cranking the engine what is voltage at b plus on the coil, if none jump 12v to it and see if it starts. If good voltage when cranking, remember it is resisted in the harness to about 7-9v, points condenser, rotor, or bad wire to points.
Old 07-30-2006, 05:34 PM
Hey thanks for the reply on my 68 impala I noticed key on 7.2 volts to ground, key in start 12 volts On the chevelle everything appears stock, points wiring etc, key on 12 volts I know the coil is good I swapped it to the Impala no problem But back on the chevelle I cant get a apark from it
Old 07-30-2006, 06:00 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Any coil reading 7/12 volts on the negative side isn't a good coil.. or the ground is shorted to voltage..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 07-30-2006, 06:37 PM
Blue Bowtie's Avatar
Registered Offender
...Unless the points are open. If the engine happened to stop with the points open, there will be voltage on the negative side of the coil.
Have a dwell meter? That would be a quick way to see if the coil has proper voltage at cranking and the points/condenser are working.
Old 07-30-2006, 06:57 PM
Let me clarify the best I can,
On my68 Impala which runs fine doing voltage checks I notice at the positive side of the coil key on (car not running)7.2 volts (car running 7.6 volts and in starting a whopping 12.2 volts
now for the chevelle That I just got (not running) the same checks showed key on (not running) 12 volts positive side and 9.6volts cranking positive side,the battery works just fine in the Impala as well. I took a jumper from the neg- side of the coil and quickly tapped it to ground (key on and I get spark) I tried 2 different distributors and dont get spark to the plugs, the cap is good tried new points and condenser
I know its probably something simple that I just over looking and I probably need to take a break I feel like Im going in circles check check check and more swapping and checking
well any ideas would be great at this point
Old 07-30-2006, 07:04 PM
Thanks blue bowtie I do but have only used it for engine running to (check and set etc.) I will go and try that right now. I have been useing a volt/ohm meter. Thanks
Old 07-30-2006, 09:35 PM
Registered Offender
...And?
Old 07-30-2006, 10:57 PM
I was assuming the point were closed.. My bad.. Did you gap those new points?
Old 08-06-2006, 01:26 PM
alblogg's Avatar
alblogg alblogg is offline
Did you fix the Prob?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 08-08-2006, 09:40 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I don't bother with any electrical equipment when I have a problem like yours. Most of the time you'll have a bad set of points or a dead condensor. I always kept a spare known-to-be-good coil around just to rule it out quickly.
Bob
