Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 07-30-2006, 01:45 PM
97Bird's Avatar
97Bird 97Bird is offline
Removing rear brake drum dust cap
OK, I'm from the old school when you used to be able to remove dust caps with a pair of water pump pliers. What's the trick in removing the 2001 Focus rear brake drum dust covers so that I can take the drum off to check my brakes?
The Original 97Bird
Old 07-30-2006, 05:45 PM
KimMG KimMG is offline
AF - Advisor
Re: Removing rear brake drum dust cap
On some Fords the drum is held on by two large phillips screws. Does yours have two screws?
Old 08-01-2006, 06:34 PM
97Bird's Avatar
I know what you mean but no there are no screws holding the drum on.
The Original 97Bird
Old 08-03-2006, 01:04 PM
shawn_carter69's Avatar
shawn_carter69 shawn_carter69 is offline
Last time I had to do it I just used a flat head screwdriver...
