Old 07-30-2006, 10:05 AM
tazman22084 tazman22084 is offline
i need help!!!!!!!!
i just replaced the fuel pump in my 1991 camaro rs and when i turn the key it still dose not turn the fuel pump on and car wont start please help!!!!!!!
Old 07-30-2006, 11:32 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: i need help!!!!!!!!
Welcome to your first post on AF.
Check for spark to plugs on engine crank?
Does fuel pump run on engine crank?
May be time to get out the old test light and check fuses and relays and for power to fuel pump.
Most of them have a fuel pump prime test wire.
Check for power there and/or jump it with a 12 volt fused jumper wire.
MT
MT
Old 07-30-2006, 12:56 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
when you put the key in the ignition and turn it just before it starts you should hear the motor prime. I would check electrical connections and fuses.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 07-30-2006, 10:17 PM
Stryker SS's Avatar
Stryker SS Stryker SS is offline
I'm sorry 92zcamaroperson, but your sig is way too specific in mods. I would hardly call accell 8.8mm wires a mod, let alone a 170 degree stat. Don't wanna be mean or anything, it's just I hate having to scroll down all the time each time you post.
'Turbo Moe'
407rwhp/429rwtq
Old 07-30-2006, 11:11 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
uhh, that belongs in a private message.
