Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-15-2002, 07:14 PM
fordhamdude fordhamdude is offline
Acura problems
I'm thinking of buying a 97 integra. I'm just wondering if there are any general problems with the integra. Not sure of the model, just curious if there are similar problems as with Hondas, which lose timing belts and water pumps at certain mileage. Any info would be helpful!!
Thanks!
Old 08-25-2002, 01:52 AM
HonDork HonDork is offline
Send a message via AIM to HonDork
You have to replace the timing belt and water pump at 90k miles or 72 months whichever comes first. But I believe it's common with most Honda's and probably a lot of other cars. If you're buying it used and it's already over 90k miles make sure you get some reciept showing that it's been done or get it done asap.
meep meep!
Old 08-26-2002, 10:54 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
check the steering. honda/acuras are known for bad axle. their boots can be easily torn and the fluid to drip out. try making a kind of tight turning, (left while driving and do the same with right). make sure you don't hear any mechanical noise.
I love them sub wufers
Old 08-27-2002, 03:45 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
If you are planning on heavily modding your acura, do not go any newer than 97, cause those are odb2 and apparently more difficult to mod.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 09-03-2002, 01:18 PM
hangcool hangcool is offline
problems
Hi, I recently bought an Integra GSR. Just to list some of the problems I had with it. My vtec solenoid was leaking oil, had to get that replaced. Also, the cv joint had to be changed, coolant turned brown relatively quick so had to get radiator flushed. Clutch master cyclinder leaking, so had to get a new one. Clutch worn out, getting heavy duty clutch. But most importantly, get the timing belt checked, if that goes, say good bye to your engine..... also, get a major service done just to be on the safe side. Most are actually wear and tear things. Hope this helps.
Old 09-15-2002, 07:16 AM
ishkie75 ishkie75 is offline
Integra
There are problems with the Acura Integra. Ours blew two months ago, and Acura won't hold up the warranty. They say it was an act of God. We have the BBB fighting it now.
Old 11-16-2003, 02:37 PM
integrasedan integrasedan is offline
Re: Acura problems
well when i got my '95, i had to replace the axles, brake master cylinder, cam/cover seals, and ignition switch.
BUT, I think it was because the previous owners didn't take good care of it. acura parts are expensive.
My car runs fine now. overall, i would recommend acuras
Old 11-16-2003, 07:03 PM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
-check the axles, paticularly the c/v boots. Honda's always turn too sharp and over time tear the rubber boots apart.
-check the timing belt! very importian!! needs to be replaced every 90k
-check over the electrical system. make sure everything works and none of the switches are broken
-check and make sure the a/c blows cold.
thats about it. take it for a test drive and beat the snot out of it.
I highly recomend Honda/Acura
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 11-17-2003, 07:41 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
i know u guys are trying to help...but look at the date.
this thread was over 2 months dead (u would have to scroll back a few pages to find this one), and the guy has ONE post and was last active that same day of his ONE post. i highly doubt he'll see this.
if u want to make a thread "Tips for buying a teg..." then sweet...but don't bring up old dead one's plz...thx.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
90 Integra GS: Problems Galore crazzzyace08 How-To's and Walk-Through's 1 12-22-2009 05:21 PM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
94 Acura Integra HELM manual like new skola239 Classifieds 0 03-22-2009 09:56 AM
