Old 07-29-2006, 11:19 PM
tracyf551 tracyf551 is offline
Driver window won't go up
My driver side window stop working suddenly. It is getting power to it. I can hear the "click" and the "strain" on it when I push the button but it won't move. PLEASE help it's going to rain!!!!!
Old 07-30-2006, 08:12 AM
dougand3 dougand3 is offline
Re: Driver window won't go up
Simple thing to try...pull the door panel and whack on the motor with a hammer...may get it moving. But it will probably fail again soon. I've tried pulling the motor off the gear box , then cleaning and lubing it - but it only lasted 5 days. Ususally have to pull motor/gearbox and regulator out, then put a new motor/gearbox in the regulator. Also, don't unbolt the gear box from the regulator until you've drilled a hole in the regulator arms and bolted them together. I think the gearbox wears too much for the power of the motor. Search "power window". Here is one with pics....
http://www.automotiveforums.com/vbul...ghlight=window
83 MB 300SD - 305k miles
93 Escort 1.9L LX Wagon - 220k miles
95 Isuzu 2.3L P'up - 230k miles
Old 07-30-2006, 11:20 PM
bychance ford bychance ford is offline
i have a '96 windstar and i had the same problem,when you pull the panel off,if it is not the motor as mentioned,there is a track toward the back of the door that the glass rides up and down in.there was a rivet that just rusted and let go,it actually dropped down into the bottom of the door.i just reached in and got it and got a new one from the dealer and if i remember correctly it was about $15 dollars.replacing was easy,one bolt i think.the hardest part is getting the door panel off,which was easy than most i have had to pull off,phillips screws and lift up.by the way,after i replaced one,the other side did the same thing in a couple of months.
