Old 07-29-2006, 08:09 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Is flat black paint useable as a primer?
It just occured to me, as I start an s-10 with a black paint job, that I've never seen black primer in a hobby shop--can normal testors flat black be used as a primer for gloss black tamiya or dupli-color?
Old 07-29-2006, 09:42 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Is flat black paint useable as a primer?
Why? A black primer is not going to make your black paint any darker. Grey primer is easier to work with.
Normal Testors what and Tamiya gloss black what? I wouldn't use enamel as a primer for anything, and I especially wouldn't ever spray laquers over it. You could use black acrylic under black acrylic (still not sure why), but for laquers stick with a laquer primer....
PHOTOBUCKET SUCKS
Old 07-29-2006, 10:11 PM
tigeraid's Avatar
Authorized Vendor
ah, I had forgotten Testors was enamel, I guess that answers the question regardless.
Old 07-30-2006, 12:36 AM
bhop73's Avatar
bhop73 bhop73 is offline
"I wouldn't use enamel as a primer for anything"
Testors/Model Master/Floquil are all enamel primer straight from the can, and i've never had a single problem with any of them... *shrug*
If you really want to use black primer. Floquil (which is supposed to be for model railroad) makes some. I use it myself when I build my Gundam models since I shade them and sand the edges to make it weathered, it saves a step of adding a dark color to shade on. You can also get black primer from Games Workshop stores, which is made for those metal mini figures for table-top games. One advantage of this one is that it comes in a big Krylon sized can and doesn't cost much more than the tiny hobby shop cans, so it's more cost effective.
http://www2.towerhobbies.com/cgi-bin...?&I=LXXA23&P=0
http://www.bhop73.com/
Old 07-30-2006, 10:56 AM
tigeraid's Avatar
Authorized Vendor
cool... I was just concerned, because this is molded in bright blue styrene, and I wanted to make sure coverage was perfect... I still don't think I'll use Tamiya over enamel though...
Old 07-30-2006, 02:57 PM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Floquil is lacquer. Usually primers are sandable, often talc is used in the formula to make it sandable. There are black primers as well as white, gray and red oxide being the most common colors. If you don't need to sand, almost any compatible paint can be used as a base... - Mark
Old 07-30-2006, 03:01 PM
bhop73's Avatar
Originally Posted by Scale-Master
Floquil is lacquer.
Hmm.. my can says 'Spray Enamel' on the label. Is there a lacquer version I can buy?
Old 07-31-2006, 02:53 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
hmmm...the floquil seems like a better choice then.
*looks at the bottles of tamiya x-1 on hand*
olly olly oxen free
Old 07-31-2006, 06:34 PM
All my Floquil is lacquer, but it's pretty old too. The newest bottle I have must be well over 10 or 15 years old. Never saw Floquil spray before, must some newfangled stuff... - Mark
