Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-29-2006, 05:24 PM
Tagahoe's Avatar
Tagahoe Tagahoe is offline
where can i find the fuel prime connection? 98 tahoe 2door
Quote: First check for spark to spark plugs.
If you have spark to plugs then jumper the fuel pump prime conection or see if it has 12 volts on it when no start.
If jumpered or it has 12 volts on it the fuel pump should run.
Mt
thanks, steve
Old 07-29-2006, 05:55 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: where can i find the fuel prime connection? 98 tahoe 2door
Mt
thanks, steve
It does not have one on yours but does have a extra fuel pump balance fuel pump on frame and a fuel pump balance module and fuel pump relay plus the oil pressure switch that shold turn on fuel pumps after oil pressure comes up and a bunch of extra crap.
Good factory service manual or a all data sub would be in order to check it out.
http://www.alldata.com/products/diy/index.html
If you need it I can post a pdf wiring diagram on it later.
5.7 engine right?
MT
MT
Old 07-29-2006, 06:15 PM
Tagahoe's Avatar
thanks man, this has been a living hell for awhile now.
yeah, 1998 tahoe 2 door 4x4, 5.7 automatic.
Old 07-29-2006, 08:16 PM
MT-2500's Avatar
AF - Advisor
Here is what i show on it.
http://members.troublecodes.net/crunch/98tahofuel.pdf
Good Luck MT
MT
Old 07-29-2006, 08:28 PM
MT-2500's Avatar
AF - Advisor
From what I get out of the repair info on it the balance fuel pump is used with the dual tank set up.
Let us know how it goes.
Good Luck
MT
MT
Old 08-02-2006, 06:43 PM
Tagahoe's Avatar
ok, i checked voltage on the prime connection, got about 4 volts on start up. i took the relay off and had 11.8-12.9 volts on the relay connection.
so im thinking the relay is bad. im gonna find out. damn i hope it works.
Old 08-02-2006, 07:48 PM
Tagahoe's Avatar
damn it, relay didnt fix the problem
