Old 07-29-2006, 03:20 PM
n5xwb n5xwb is offline
Dash board removal to fix A/C door
They Olds Group;
I have had this common problem with hotter air for the driver.
After doing a lot of research on this problem even removing and CAL the actuators. I noted that the driver side actuator shaft felt strange. It appears that the door is broken inside the air box. To this end of repairing this problem I need to remove the dash completely. I have it almost loose but the back end near the defroast side will not come loose. I have look for bolts, nuts and/or clips - but I have not seen the key. Has anyone gotten it loose?
The console, speedometer cluster, radio and temp control are out. The passenger air bag is in. (anyone removed one?). The bottom is loose
73 de Donn Washburn
Ham Callsign N5XWB Email: " [email protected] "
307 Savoy St. HAMs : " [email protected] "
Sugar Land, TX 77478 BMW MOA #: 4146 - Ambassador
LL# 1.281.242.3256 VoIP via Skype: n5xwbg
" http://counter.li.org " #279316
Old 08-01-2006, 08:58 PM
Re: Dash board removal to fix A/C door
Well Group;
I got the dash board out. Not a simple task. Just getting all of the electrical cables loose is a task. Next is the air condition ddoor on th drivers side. This is to fix the driver side hot problem.
Anyone need info - get "www.skype.com" and call n5xwbg
email to n5xwb at hal-pc.org
Old 06-27-2007, 09:16 AM
Rolm's Avatar
Rolm Rolm is offline
How difficult is it to remove the Speedometer cluster on an Olds Intrigue
