Old 07-29-2006, 02:17 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
camshaft questions
ok so i see some regualr performance cams out there that say works with stock valve train but what about the oens that say valvetrai nrequired. do you only need to srpings and retainers or lie ka hole valve train. also will ie ver have to worr yabout the valves hitting the pistons.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 07-29-2006, 07:20 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: camshaft questions
valve, springs, retainers, and most of the time you will have to shim them to get proper adjustment and pressure out of them. Valves hitting the pistons isnt much of a convern with stock, or low compressoin pistons, and most well designed high compression pistons dont have many issues, but it is something that can happen. A radical cam will also require more than just a valve train upgrade, you will need headwork done to take full advantage of the extra lift and duration.
Old 07-30-2006, 06:41 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
ya need some grammer check! i just bought all my valvetrain parts(and a lil extra) it set me back 2k. once all my stuff came in, i sent it to my local shop. they are installing it now. just make sure to buy crower keepers. it took me a week to get 'em. i'm gonna try and get the ctr cams. but i gotta b16. head work is recommened. it don't cost much, especially with a homie hook up. but yeah it is great for an upgrade.
-tony-
2000 honda s2000
Old 07-30-2006, 11:00 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Not its not. CTR cams can work with stock valvetrain. I've used it on my poor mans type r set up. 3 of my boys had a stock b16 with ctr cams and also worked fine.
Old 07-30-2006, 01:47 PM
well some cams work fine without a valve train but im jsut asking about the oens that need valvetrains. would i jsut need sprigns and retainers or should i buy aftermarket valves. other wise im jsut gonna buy new oem ones.
06 cbr 600 f4i
91 civic hatchback.
Old 07-30-2006, 01:56 PM
mellowboy's Avatar
Well be more specific. It depends what cams your getting. CTR cams does not require valvtrain upgrade. I ran with it my motor just fine. CTR would be a nice upgrade.
Old 07-30-2006, 02:32 PM
well theres either the crower stage 2 cam. says requires springs and retaienrs of the comp cams camshaft that says requires springs.
06 cbr 600 f4i
91 civic hatchback.
Old 07-30-2006, 04:07 PM
i was just saying to get the full potential out of the cams, upgrade the valvetrain and then do some head work! i would recommend it.
-tony-
2000 honda s2000
Old 08-09-2006, 06:46 PM
honda_luvr_2000 honda_luvr_2000 is offline
just a warning, i bought a block off a guy that put in an aftermarket cam w/o upgrading valvetrain, popped a valve head right off and lodged it halfway through the piston, maybe i'll get a pic up one day. pretty nifty lookin. so like the others said if it recommends a valve train upgrade do it. some only recommend valve springs and retainers, some everything. just get a hole of tech support for whoever u'r buying the cam from and ask them. pretty easy really.
Originally Posted by Greenblurr93
ahh i see said the blind man to his deaf wife, as he pissed into the wind, its all coming back to me now.
Old 08-10-2006, 12:26 AM
how did a block have an upgraded cam. don't you mean a engine, and yes it does depend on what kind of cam you buy, but for me and my taste if i'm gonna do one thing i might as well do two or three more, that's why i have so many parts on my car now.
-tony-
2000 honda s2000
Old 08-16-2006, 10:28 PM
no. i meant exactly wut i said, i bought a block off of a guy who had put a cam in the head that WAS on the block. when it went k-put, he took it apart, i bought the block, he kept the head.
Old 08-17-2006, 12:13 AM
how bad was the piston and cylinder wall damaged???
-tony-
2000 honda s2000
Old 08-17-2006, 11:10 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Yea, if they recommend a valvetrain upgrade, call them up, tell them what you have planned and most of them will work with you and figure out what you need exactly.
Tony
91 Civic Sedan DX - Stock 287k Miles
